Author Topic: More I look more I am confused  (Read 3695 times)
Offline lanox
« on: Mon, 13 June 2016, 05:26:51 »
Hi
I am looking to get a nice compact keyboard, that supports mac and windows via switches. I have narrowed it down to the following keyboards but still can't seem to decide.
I am aware that not all of these keyboards have support for mac but they are still on the list.
1) HHKB ( supports both), but hard to get keycaps.
2) Leopold FC660C (although no support for mac) love the layout.
3) KUL-ES87
4) matias 60% (but only can choose mac or win)
5) CODE 61-Key ( supports for mac and win)
I would like to hear what you guys think, and if I have missed any other keyboards.
Thanks
« Last Edit: Mon, 13 June 2016, 06:23:40 by lanox »
Offline HeeCh2ei
  • qdrw
Re: More I look more I am confused
« Reply #1 on: Mon, 13 June 2016, 06:13:18 »
You can find your answer as soon as you dig deeper.
You have a Cherry MX keyboards in the list. What mx switches you prefer?
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline lanox
« Reply #2 on: Mon, 13 June 2016, 06:16:41 »
I am not sure what you mean with the first line.
I am after Cherry MX Brown.
thanks
Offline bocahgundul
  • a seal
« Reply #3 on: Mon, 13 June 2016, 06:20:14 »
I think your best bet is the HHKB which support both mac and windows and it use Topre switch
They feels really good and the build quality is good!
Offline lanox
« Reply #4 on: Mon, 13 June 2016, 06:23:18 »
I am almost sold on HHKB, I am just little annoyed that keycaps are not as easy to get as Cherry.
Offline HeeCh2ei
  • qdrw
« Reply #5 on: Mon, 13 June 2016, 06:27:43 »
thanks
I am sold keyboard on browns once I tried Topre.
Offline lanox
« Reply #6 on: Mon, 13 June 2016, 06:31:09 »
thanks
Sorry but I got no idea what you talking about.
Offline bocahgundul
  • a seal
« Reply #7 on: Mon, 13 June 2016, 06:32:36 »
well why did you want to change the keycaps?
they got a really high quality dyesubbed PBT keycaps
Offline lanox
« Reply #8 on: Mon, 13 June 2016, 06:34:34 »
Ah I guess just modding etc, make it look nice dunno some HHKB I have seen on here are amazing.
Offline Malenky
« Reply #9 on: Mon, 13 June 2016, 06:39:47 »
I think you should be more specific about what you mean by 'supports Mac'. Any keyboard will work on a Mac, you may have to remap the control and alt keys to get your keys how you like it in OSX but that's about it. I think if you're looking for a keyboard which can do more specific things such as the controls they have bound to the base layer of the function keys, then maybe a Matias keyboard is your best choice? Not 100% sure on what Mac controls they have though.
Offline HeeCh2ei
  • qdrw
« Reply #10 on: Mon, 13 June 2016, 06:42:43 »
thanks
Sorry. Don't listen to me, my mind is drifted today.
Offline lanox
« Reply #11 on: Mon, 13 June 2016, 06:49:17 »
Right, sorry I was not aware of that. What I meant was to be able to use keyboard for mac os and windows with out having to change a lot.
I will do some more reading my self on this.. But thanks for clarifying it.
Offline Rumudiez
« Reply #12 on: Mon, 13 June 2016, 15:02:41 »
Yup. I have a cheap rosewill at work and a kbt pure at home. I just remapped control and caps lock to command and I'm done.
Volume shortcuts on the pure work with both OSes out of the box. I wrote a script and bound it to f14/f15 to adjust brightness for the rosewill.
40% layout, anyone?
Offline lanox
« Reply #13 on: Mon, 13 June 2016, 17:47:25 »
Thanks I think this has helped a lot on making my decision.
« Reply #14 on: Sun, 19 June 2016, 00:41:25 »
I've used all sorts of keyboards on a Mac and Windows, including HHKB, CODE TKL, Model M, SSK, NED APC-H4100E, ...
The only thing I have to change is to swap Win and Alt, which I do in Mac's System Preferences.
140107-0
