Author Topic: Handful of purple keycaps needed  (Read 3518 times)
Offline rushonerok
    • Rush's Blog
« on: Mon, 13 June 2016, 15:08:15 »
I am looking for handful of key caps and hoping someone here might be able to point me in the right direction
1x DCS 1 SPACE row 1
4x DCS 1 SPACE row 4
PBT plastic, blank, in Signature Plastics colors RCB and RCE (both are purple)... not sure which one would look better so I want to get both.
I looked on the Signature Plastics website first but they don't have the row and color I need listed. Where else would I be able to get these?
Re: Handful of purple keycaps needed
« Reply #1 on: Mon, 13 June 2016, 15:18:48 »
I'm not sure you are going to find anything DCS and PBT from anywhere.
DCS is a signature plastics profile similar to cherry profile but not quite the same.
Offline rushonerok
    • Rush's Blog
« Reply #2 on: Mon, 13 June 2016, 15:42:15 »
Oh wow, didn't know that! The woman I talked to there said I could custom order them but there is a $100 minimum. I just put together my "WhiteFox" board but want the blue keys to be purple with purple LEDs (I was inspired by the purple zealios)... If I custom ordered the key caps I'd have to sleep with one eye open so my wife doesn't kill me in the middle of the night. Totally worth it though?!?!  :-\
« Reply #3 on: Mon, 13 June 2016, 15:53:02 »
Sorry I meant if you couldn't get them from signature plastics directly you wouldn't find them anywhere else.
My suggestion was going to be contact Melissa but sounds like you did that. :thumb:
Offline Bigpock
« Reply #4 on: Mon, 13 June 2016, 17:32:41 »
I have a brand new blank base set of purple keycaps from pimpmykeyboard.com
id sell them to you
