Author Topic: Florence like software with ergodox layout?  (Read 3517 times)
Offline edge226
« on: Tue, 14 June 2016, 13:06:18 »
I purchased an Ergodox and since it is a split keyboard that alone got my creative mind going.
I stream programming and I am now thinking of greenscreening out my desk and having a cam pointed at my hands. I would most likely have some transparency on that layer so that layer did not completely cover peoples view.
I would then like to have a program similar to Florence that can display the keys I press onscreen when I press them. I would like to overlay this on top of my hands. Again with transparency and probably chromakey effects to remove the keys that are not pressed.
Does anyone know of a program like this I could use that either has the ergodox layout already or is easy enough to modify with a ergodox layout?
Please only suggest alternatives that will work on Linux.
« Last Edit: Tue, 14 June 2016, 13:08:06 by edge226 »
