Author Topic: Can you swap Cherry brown tops onto blacks?  (Read 2681 times)
Offline didjamatic
« on: Mon, 28 December 2009, 16:40:16 »
Hmmm, tried searching but wasn't 100% clear (likely due to being pumped full of cold medicine today)
Can you simply pop the switch tops off of Cherry Blacks and install tops of Cherry browns or is this a soldering gun mod?
Offline itlnstln
« Reply #1 on: Mon, 28 December 2009, 16:50:18 »
Yes.
The method in which you do it would depend on the switch mounting.  Plate-mounted 'boards (Filco, Das III, etc.) require soldering.  PCB-mounted 'boards (Cherry Corp.) can be swapped without soldering; you just pop the top.
Offline didjamatic
« Reply #2 on: Mon, 28 December 2009, 16:54:34 »
Awesome, thank you
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Mon, 28 December 2009, 18:07:27 »
How do you think Cherry switches like that would feel? I haven't heard of people doing that before.
Offline ch_123
« Reply #4 on: Mon, 28 December 2009, 18:14:11 »
Quote from: didjamatic;146007
I would imagine that soldering would prove much quicker if you were doing a full board swap.
Offline overdriver
« Reply #5 on: Mon, 28 December 2009, 18:44:07 »
Quote from: itlnstln;146011
Yes.
Thanks for info. I was curious about this too.
btw, what about Scorpius M10 ? Is it PCB-mounted?
OmniKey 101 - the perfect keyboard
Chicony KB-5181 - SMK Monterey Blue switch
Cherry G86-6241OEUAGSA - Cherry Brown switch
IBM M 1378160(Ambra)
Dell AT101w / AEK II
Offline ricercar
  • mostly abides
« Reply #6 on: Mon, 28 December 2009, 20:42:42 »
Quote from: overdriver;146039
Yes. Linky
Offline dougy
M10
« Reply #7 on: Tue, 29 December 2009, 05:59:31 »
The pics don't show it but there is metal plate mounting. Looking at a modded one it doesn't look like you can remove the cap without desoldering from the board.
Offline timw4mail
    • https://timshomepage.net
« Reply #8 on: Tue, 29 December 2009, 07:42:00 »
Quote from: dougy;146139
You can see if you look between the keys, that a Scorpius M10 is actually plate-mounted. Just looking at the back of the PCB isn't going to show you much.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
« Reply #9 on: Tue, 29 December 2009, 09:01:27 »
Quote from: microsoft windows;146024
Like crap.  I did a switch swap on the spacebar of one of my 'boards (putting a grey spring in a brown switch).  The brown with the grey spring lost almost any tactility it had.  It pretty much feels like a black.
Offline overdriver
« Reply #10 on: Tue, 29 December 2009, 12:57:44 »
Quote from: timw4mail;146146
oh crap. so no keyswitch swapping with M10 without soldering ?
