Author Topic: Suggestions on my next keyboard?  (Read 1312 times)
Offline check009
« on: Thu, 16 June 2016, 12:05:49 »
Hi, all!
First of all, greetings from Singapore! Hope I'll be able to contribute to the forum in my limited capacity.
I'd like to hear your suggestions on the possible options I could consider for my next mechanical keyboard.
Currently, I am using Filco Majestouch Ninja Tenkeyless, which I've been using for about a month after moving from CM Storm.
Below are some requirements I have for my next keyboard:
  • Budget: Approx US$100+
  • Switches: Cherry MX Red/Brown
  • Numpad! - Unexpected need for full sized keyboard for work
  • Must be ergonomic - CM Storm Ultimate felt too tall and my wrists were bent unnaturally
  • Low profile design preferred
Thanks for reading! Hope you can share your wisdom with me haha.
Offline lee+
Re: Suggestions on my next keyboard?
« Reply #1 on: Sat, 18 June 2016, 18:25:02 »
Cherry MX Board?
I can't tell what the prices are like in Singapore.  The 6.0 may be out of the price range while the 3.0 might fit.  Both have low key caps, so I suppose they could fall under "low profile".
Does it have to be a new one, or is used ok, too?
