Author Topic: Plate-Mounted 60% Topre Board?  (Read 2508 times)
Offline Hypersphere
« on: Fri, 17 June 2016, 09:14:40 »
Do you ever wish for a plate-mounted 60% Topre-switch keyboard?
I like my HHKB Pro 2, but sometimes I would prefer it to feel more solid, like my Realforce 87U boards with their plate-mounted Topre switches. I can make the HHKB switches heavier by transplanting 55g domes, but it would still have case-mounted switches.
Similarly, I enjoy my RF boards, but when I am using them, I wish they could exist in a 60% form factor.
Would PFU ever consider producing a HHKB with a plate-mounted switch option?
Would Topre/Realforce ever consider producing a plate-mounted Topre-switch 60% board?
How difficult would it be to build a custom 60% Topre-switch keyboard?
Offline bocahgundul
  • a seal
Re: Plate-Mounted 60% Topre Board?
« Reply #1 on: Fri, 17 June 2016, 09:21:27 »
have you considered leopold fc660c? its basically a 60% realforce.
And I think its not possible to build a custom 60% topre switch keyboard without designing the PCB first
Offline ideus
  • Björkö.
« Reply #2 on: Fri, 17 June 2016, 09:26:35 »
At least, it is not in the realm of DIY for aficionados.
Offline Hypersphere
« Reply #3 on: Fri, 17 June 2016, 09:27:11 »
@bocahgundul: Yes, the Leopold FC660C was my very first Topre-switch keyboard. It is nice and solid, but I could never get accustomed to the layout or form factor. Later, after trying many different keyboards with various form factors, layouts, and switches, I discovered that my form factor preferences were quantized: 60% or TKL, but nothing in between.
