Author Topic: Why the Hebrew layout has its brackets swapped?  (Read 2904 times)
Offline spremino
« on: Sat, 18 June 2016, 10:59:32 »
Both round and curly/square brackets are swapped - that is: the closing bracket is on the left of the opening one - when compared to all other layouts that I know.  Does anybody know the reason for sure?
A long space bar... what a waste of space!
Re: Why the Hebrew layout has its brackets swapped?
« Reply #1 on: Sat, 18 June 2016, 11:06:53 »
jew know i never noticed that
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Sat, 18 June 2016, 15:15:27 »
Right-to-left writing system.
Sincerely,
Cpt. Obvious
Offline HeeCh2ei
  • qdrw
« Reply #3 on: Sat, 18 June 2016, 15:19:35 »
Just another instance of QWERTZ leetness.
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
Offline davkol
« Reply #4 on: Sat, 18 June 2016, 15:21:52 »
…and for the really lazy, a direct quote from the relevant Wikipedia article:
One noteworthy feature is that in the standard layout, paired delimiters -– parentheses (), brackets [], braces {}, and angle brackets (less/greater than) <> –- have the opposite visual representation from the standard in left-to-right languages. Thus, an open parenthesis in a right-to-left language has the same visual representation as a close parenthesis in a left-to-right language. Key mappings follow the logical rather than the physical representation. For instance, whether on a right-to-left or left-to-right keyboard, Shift-9 always produces a logical "open parenthesis". On a right-to-left keyboard, this is written as the Unicode character U+0029, "right parenthesis": ). This is true on Arabic keyboards as well. On a left-to-right keyboard, this is written as the Unicode character U+0028, "left parenthesis": (.
Offline Malenky
« Reply #5 on: Sat, 18 June 2016, 16:03:36 »
The answer to this is so oddly satisfying.
