Author Topic: Just a quick "Hello!"...  (Read 2865 times)
Offline dustigroove
« on: Sat, 18 June 2016, 13:04:59 »
After a great many years working with computers, I've given myself the much-needed push to finally LEARN HOW TO TYPE... after all, what better way to inspire ones-self to stop hunting and pecking than to put your wallet in the game.
Here's to hopefully learning, growing, and (very likely) sharing in a brand new obsession, cheers!
DG.
« Last Edit: Sun, 19 June 2016, 01:31:20 by dustigroove »
Offline reaper
Re: Just a quick "Hello!"...
« Reply #1 on: Sat, 18 June 2016, 20:46:06 »
Welcome to Geek Hack!  :)
Din Eli
« Reply #2 on: Sun, 19 June 2016, 01:47:53 »
Welcome to Geekhack!
You'll probably find that switch and keyboard layout become more critical when you are trying to type properly.  Hunt and peck doesn't really have a formal hand position, so you can get used to hitting the keys in whatever way works best for you.  But proper touch-typing has its rules and practices, and depending on how long you've been hunting/pecking could take a while to learn.
I should probably touch type more - I know how to, but sometimes it's still easier to use a weird style that I taught myself before I knew there was a proper way to type :))
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Sun, 19 June 2016, 08:49:48 »
Cool, welcome. What layout are you going to learn?
Offline dustigroove
« Reply #4 on: Sun, 19 June 2016, 21:51:28 »
Thanks reaper, happy to have stumbled upon GH!
Thanks Rowdy! With the number of years that I've typed the way I do, I'm pretty sure that I'm facing an uphill battle... although I find that having a hobby or passion that coincides/overlaps with what you are trying to learn makes the journey just a bit easier. I figure by throwing myself into learning more about keyboards themselves, maybe do some modding, and perhaps a custom build... tinkering that I generally enjoy, I will keep myself focused while I make the climb.
Thanks csmertx. I didn't plan to learn an alternative layout like Dvorak or Colemak initially... just sticking with common QWERTY. I had however planned on using a full-size kb but was just gifted a white Vortex Pok3r... not sure if a 60% is a good place to begin? Will it matter?
DG.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sun, 19 June 2016, 22:01:08 »
DG.
I'm not sure if a 60% keyboard will matter tbh. I tried Dvorak off and on, but I've been touch typing qwerty for nearly 17 years so I'll either have to dedicate a month to Dvorak to really see if I like it or just stick with qwerty haha. You'll have to use a lot of Fn hotkeys on the 60% but maybe that'll help with burning the qwerty layout into your memory? I'm not a programmer so I still look down at the keyboard for simple html/shortcuts /shrug
« Reply #6 on: Mon, 20 June 2016, 06:01:46 »
DG.
Gifted a Pok3r?  Nice gift! :D
