Author Topic: maximum cable length?  (Read 5354 times)
Offline lee+
« on: Sat, 18 June 2016, 13:18:32 »
Hi,
what's the maximum length a keyboard cable can have, for keyboards with PS/2 and DIN connectors?  Is there a specification stating a maximum length?
Offline Tactile
Re: maximum cable length?
« Reply #1 on: Sat, 18 June 2016, 13:30:09 »
REΛLFORCE
Offline lee+
« Reply #2 on: Sat, 18 June 2016, 13:36:30 »
50m is a bit optimistic as an estimate, IMHO.  IIRC, parallel printer cables are specified for max. 20m, and they use 12V signals.
In any case, I'll probably be more limited by the max. length of the display port cable.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Sat, 18 June 2016, 14:00:55 »
Longest one I have is a 3 metre SDL cable for a model M, although it's coiled so it stretches comfortably beyond that.
Offline rm-rf
« Reply #4 on: Sat, 18 June 2016, 14:08:24 »
depending on what kind of display port you are using...
search for "KVM cable"
Offline Bucake
« Reply #5 on: Sat, 18 June 2016, 14:14:20 »
coiled is so bad though. snags on everything, and most of them are too stiff anyway. terrible!
Offline QuincyJones
« Reply #6 on: Sat, 18 June 2016, 14:35:20 »
eugh - who wants to have to carry their cable in a wheelbarrow?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline kawasaki161
« Reply #7 on: Sat, 18 June 2016, 14:45:00 »
Also kinda depends on the quality of the cable and if it is in one piece or with some extensions. Cheap extension cables tend to have problems after 6-10m, good quality one-piece cables can be much longer.
Offline lee+
« Reply #8 on: Sat, 18 June 2016, 16:22:46 »
That's display port 1.2 --- only the 3rd cable I got finally worked.
I guess once we get 8k displays, we'll need optical cables because the transfer rates will be too high for copper ones.  It would already make sense with 4k.
Offline lee+
« Reply #9 on: Sat, 18 June 2016, 16:29:27 »
Tell me about it.
But then, I'm considering getting a coiled one as it would fit so well to two of my keyboards.  It would be just right somehow, and I don't need to carry it around.
Also, they're probably cheap because nobody in their right mind would want one ;)
Offline Bucake
« Reply #10 on: Sat, 18 June 2016, 17:10:42 »
Tell me about it.
if you say you have a good reason, i will allow it
Offline lee+
« Reply #11 on: Sat, 18 June 2016, 18:00:54 »
Tell me about it.
You're so generous :)
I made up my mind, I do want a coiled one.  There's a lot to be said for a coiled cable, like it would simply be too short if it wasn't coiled.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #12 on: Sat, 18 June 2016, 18:27:46 »
Hi,
Depends on the resistance (and thus purity) of the cable material.  Theoretically, an electrical signal can propagate infinitely, given a zero-impedance medium, but such a medium hasn't yet been discovered.
Offline lee+
« Reply #13 on: Sun, 19 June 2016, 14:20:45 »
Hi,
At some point it would take too long for the signals to travel from the keyboard to the computer, and you would feel as if you were using an USB keyboard.
