Author Topic: Cherry G84-4100 - $110 at Newegg  (Read 4569 times)
Offline Viett
« on: Tue, 29 December 2009, 01:30:03 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823333019&cm_re=mechanical_keyboard-_-23-333-019-_-Product
The fifth mechanical keyboard to reach Newegg's lineup. A bit pricey, though.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline elbowglue
« Reply #1 on: Tue, 29 December 2009, 01:33:38 »
This is almost the same layout as my g86 from ebay! Beware the \ next to the  alt key.  Talk about a small spacebar too.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline timw4mail
    • https://timshomepage.net
« Reply #2 on: Tue, 29 December 2009, 07:24:43 »
Now if Newegg would just sell the G80...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline didjamatic
« Reply #3 on: Tue, 29 December 2009, 07:59:19 »
Cool, compact, but that would turn me from a touch typist into a hunt-and-peck typist in 2.2 seconds.  Look at all those little keys.  You could fit the enter, r shift and backspace keys on one Model M backspace key.
Offline timw4mail
« Reply #4 on: Tue, 29 December 2009, 08:22:54 »
Quote from: didjamatic;146154
I'm a weirdo with long skinny fingers that doesn't have too much trouble touch-typing on a smaller keyboard like that.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Tue, 29 December 2009, 08:45:45 »
That keyboard has a terrible layout. The original Model F's beat that layout by a landslide.
Offline Hofy
  • Voids Warranties
« Reply #6 on: Tue, 29 December 2009, 17:39:59 »
$110!!  Yikes
I bought my white one w/o win keys off ebay for $10
Poker II Cherry MX Blue
Filco TenKeyless Zero Fukka
Cherry ML4100
IBM Model M 1391401 Buckle Spring Luvin
Offline Rajagra
« Reply #7 on: Tue, 29 December 2009, 18:16:15 »
These are great as auxillary keyboards (I use a KVM for my main keyboard, but have 2 ML4100s connected so I can type on either PC quickly without hassle.)
They are even good for alternative layouts, since the keys are all the same height.
Unfortunately, the \ key is slightly wider than the # key on the UK version, so I couldn't quite get a perfect Colemak layout. If I was bothered, I suppose it could be filed down to make the swap possible.
This would be a good way to learn an alternative layout if you want to leave the keyboard you type on as Qwerty or blank. The ML4100 would act as a visual guide when you need to check a location. As a bonus if you need to type anything critical like a password, or type one-handed when you use the 'phone, you can go to the ML4100.
Having typed on them for a bit recently, I have to say the switches are slightly 'balky'. Not dreadful, but clearly a step below MX switches.
« Reply #8 on: Tue, 29 December 2009, 19:15:55 »
Did you switch the Caps-lock and Backspace keys on that?
Offline Rajagra
« Reply #9 on: Tue, 29 December 2009, 19:30:38 »
Quote from: microsoft windows;146399
Physically, yes. The keycap sizes are identical. No Photoshopping this time.
In XP Colemak makes CapsLock act as Backspace. In the beta driver for Vista it doesn't, so I remap it using KeyTweak.
I don't remap the (normal) backspace key as CapsLock, but I'm so used to having backspace on the left now, that I may end up doing that. At least in Vista where I get the choice.
