Author Topic: Mechanicalkeyboards.com  (Read 2037 times)
Offline jcoffin1981
« on: Sun, 19 June 2016, 03:10:54 »
I browse the site fairly often, but literally about half the time I get a "connection times out error."  It's not just at a specific time when they may be doing site maintenance, but anytime.  Is this just my computer or is this a real occurrence?  It's probably the best place to shop here in the US, unless anybody else can suggest something?  Do these error messages happen to you?
EDIT:
Okay, this is really weird.  If I activate a VPN, the site immediately works.  If I shut it off and attempt to reconnect I get the same error  message.  I'm sure there are lots of people on here who are smarter than me. What's going on?
« Last Edit: Sun, 19 June 2016, 03:45:16 by jcoffin1981 »
Offline lee+
Re: Mechanicalkeyboards.com
« Reply #1 on: Sun, 19 June 2016, 06:06:45 »
It works fine here, might be some network issue you're having.
Offline QuincyJones
« Reply #2 on: Sun, 19 June 2016, 06:25:11 »
either it's some delay in your loudly proclaiming freedom-minded government monitoring your activity, or your isp has a routing issue. your call
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline Hypersphere
« Reply #3 on: Sun, 19 June 2016, 07:10:48 »
I have experienced the same thing with the MK site. I emailed them from a working connection to inquire. After they did quite a lot of troubleshooting, it turned out that their server was blocking my IP address because there were too many connection attempts, which their settings interpreted as a cyber attack. After some time, they allowed connections from my IP address again.
Offline jcoffin1981
« Reply #4 on: Sun, 19 June 2016, 13:05:46 »
This is interesting.  I browse the site once a week or something.  I don't recall ever trying to connect many times or having lots of browser windows open or something.  Calling them to unblock me is too much hassle, so I will just use the VPN if I have to.
Offline Data
« Reply #5 on: Tue, 21 June 2016, 06:43:01 »
Really doubt that they're blocking you.
This sounds like it could be a DNS or routing issue.  Have you tried replacing your ISP's provided DNS servers with Google public DNS to see if it helps?
8.8.8.8
8.8.4.4
They have a vendor forum here and their employees are regular GeekHack users.  Have you tried asking them?  It wouldn't be nearly as difficult as you implied.
