Author Topic: IBM Terminal Keyboard Controller  (Read 1749 times)
Offline Sp1der
« on: Sun, 19 June 2016, 10:32:23 »
Hello,
I recently ordered a cheap IBM Terminal Keyboard (1394312) off eBay and took it apart because it was very filthy. I took a look on the controller and saw 4 pairs of jumper pins of which one was shorted by a jumper. I attached a picture of the controller, so you can see it. Does anybody know what the different jumper pins do?
Offline 122obsessed
  • I like 122 terminals
Re: IBM Terminal Keyboard Controller
« Reply #1 on: Tue, 28 June 2016, 12:10:49 »
If its similar to the controller on my board they configure the ID code of the keyboard. Usually they are safe to ignore.
« Last Edit: Tue, 28 June 2016, 12:15:02 by 122obsessed »
Offline Sp1der
« Reply #2 on: Tue, 28 June 2016, 12:13:52 »
Thanks for your answer. I don't have any DIP switches on the bottom of my keyboard. Do you know what they do?
Offline 122obsessed
« Reply #3 on: Tue, 28 June 2016, 12:15:52 »
They provide the ID code to the keyboard.
