Author Topic: Howdy!  (Read 2082 times)
Offline glyakk
Howdy!
« on: Sun, 19 June 2016, 16:52:30 »
I have had a long time fascination with typewriters and fairly recently realized that you could get the same satisfying sounds from a keyboard. I bought a ducky zero about three years ago and then a CoolerMaster Quickfire TK that I am using as my main board at home. I also picked up a kinesis advantage recently that I use at work. I also bought a Atreus recently and have started assembling it. Its my first time building something like this and I get the feeling I am going to get addicted.
I am also looking at the onehand chording keyboard. It reminds me of 13 or so years ago, the frogpad I could never afford for the car computer I was building at the time.
Re: Howdy!
« Reply #1 on: Mon, 20 June 2016, 06:00:18 »
Welcome to Geekhack!
Sounds like your addiction is well underway :)
If you like the sound of mechanical typewriters, perhaps a Model M or a Model F would better capture the sound.  Or even a beam spring keyboard!
What switches are you using in those keyboard?
