Author Topic: Switches for Planck build.  (Read 2122 times)
Offline cpeterson19
« on: Mon, 20 June 2016, 20:55:11 »
Hello,
I'm doing a Planck 40% build and I need reccomendations on which switches to use. I currently have boards with cherry mx blues and zealios (aka gateron purples).
GH please help#
Sent from my LG-H830 using Tapatalk
Offline cpeterson19
Re: Switches for Planck build.
« Reply #1 on: Mon, 20 June 2016, 21:08:15 »
I wouldn't mind trying alps, thought?!
« Reply #2 on: Tue, 21 June 2016, 02:46:20 »
If you want to try Alps style Matias quiet clicks are lovely and easy to get, but you're not going to find blanks or 1u keycaps with correct legends to put on a planck so I'd stick with MX like.
Get some 120g linears and give your fingers a workout :))
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Tue, 21 June 2016, 03:32:59 »
ALPS are the bomb but like suicidal_orange said it's not easy to find keycaps for them.
Gateron Clears are pretty neat. Smooth and extremely light.
Offline Data
« Reply #4 on: Tue, 21 June 2016, 06:28:48 »
I put MX Blacks in my Atomic.  No regrets.
Offline cpeterson19
« Reply #5 on: Tue, 21 June 2016, 08:38:23 »
Couldn't I buy dsa Keycaps from like pimpmykeyboard.com wouldn't that work for alps?!
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #6 on: Tue, 21 June 2016, 09:06:24 »
Which switches do you prefer between your Cherry MX Blues and Zealios (I'm going to guess the latter)?  Also, is there any specific switch that you've been looking to try, i.e. linear, more or less force required, etc?  This might help for people to give you recommendations. But hey, if you really enjoy one of the switches that you've tried then there's no harm in sticking with them.
[WTB] HHKB Black
