Author Topic: Hi, I'm new :)  (Read 3480 times)
Offline DanielJanzon
Hi, I'm new :)
« on: Wed, 22 June 2016, 05:58:33 »
Hi Geeks :)
I'm a qwerty guy always on the lookout for better keyboards. Ergonomics is my main concern. I use Truly Ergonomic Keyboard (TEK) at work and Ergodox at home. Both with Cherry MX Brown. I have also used a Kinesis Advantage which was great too.
One thing I can highly recommend is textured key caps which I have on my Ergodox. So much nicer for the finger tips. I personally believe it has something to do with how the nervous system appreciates rich input. Sort of how it is nicer to look at the nature than a white wall. From a practical point of view it helps navigating the keyboard by sense rather than looking down, as I have a variety of textures.
On the opposite side of what I like, my worst nightmare, we find Apple key boards (and all copies) with blank flat keys.
Re: Hi, I'm new :)
« Reply #1 on: Wed, 22 June 2016, 06:08:15 »
Welcome to Geekhack!
Textured keycaps?  In what way?  All I can think of is the uniform PBT rough texture (probably not, based on your description) or Braille.
A few people have asked about Braille keycaps, but none have come to light.
Have you got any more info or even pictures of your keycaps?
Thanks, and enjoy your stay :)
Re: Hi, I'm new :)
« Reply #2 on: Wed, 22 June 2016, 06:16:02 »
I bought them from WASD*. There is a lot more to do in this respect though. I'd like to have textured key caps made of clay/ceramics or something with similar feel. Compare poker chips made of plastic to those made of clay. The ones from WASD are 3D printed (I guess) caps with very plastic feel. Extremely expensive as well after customs tax and freight costs in Sweden.
* http://www.wasdkeyboards.com/index.php/products/printed-keycap-singles/textured-cherry-mx-keycaps.html
Offline shadowku
Re: Hi, I'm new :)
« Reply #3 on: Wed, 22 June 2016, 22:24:58 »
I never thought about textured keycaps...
Now I really want to try braille keycaps.
HHKB Pro2      FC660C
Re: Hi, I'm new :)
« Reply #4 on: Sun, 26 June 2016, 00:41:20 »
Thanks for the link, I'd completely forgotten that WASD do those.
They are not 3D printed, just molded in some way, and fairly thin.
Clay keycaps would be too fragile, I imagine.  And ceramics - wouldn't that be difficult to work with at keycap scale?
A few times people have been talking of glass keycaps, but I'm not sure anything definite ever came of it.
Re: Hi, I'm new :)
« Reply #5 on: Mon, 27 June 2016, 01:11:08 »
@shadowku,
Braille keycaps is a great idea. I have some keys with a single spike/dot in the middle[1]. Those are really easy to feel and great for keys you have to reach for, I imagine braille being somewhat like that but with greater variety. The textured keys I have do not have very strong identity per texture; more development can be done in this respect.
Btw, maybe you will learn braille as a by product of having such keys?
[1]  http://www.wasdkeyboards.com/index.php/products/blank-keycap-singles/row-2-size-1x1-dot-cherry-mx-keycap.html
@rowdy,
I think you're right. There might also be a weight problem. You want the key to pop back up rapidly. Don't know if the spring in regular switches would be able to deal with it. If they would, they would be needlessly hard to push down.
Re: Hi, I'm new :)
« Reply #6 on: Mon, 27 June 2016, 05:27:37 »
There's a lot of plastic in SA keysets, especially sculptured SA.  To me they seem to work best on heavier switches, like blacks (as I'm using now), greens or clears.
I guess if the springs in the switches are strong enough you could have keycaps made from lead!
Except for the poisonous side-effeects of lead, of course.
And the fact that it is sufficient soft that the keycaps would deform over a fairly short period of time.
And they wouldn't look very nice either.
Ok, scrub that, lead keycaps is a BAD idea :p
Re: Hi, I'm new :)
« Reply #7 on: Wed, 06 July 2016, 03:48:30 »
Maybe aluminum with a rugged surface?
Off-Topic add-on to my presentation: I also have an Alpha-Grip which is a great idea for typing with relaxed shoulders and good posture, but it didn't feel nice on my (XL) hands.
Re: Hi, I'm new :)
« Reply #8 on: Wed, 06 July 2016, 05:46:09 »
Aluminium with a rough top surface?
https://geekhack.org/index.php?topic=78796.0
Re: Hi, I'm new :)
« Reply #9 on: Wed, 06 July 2016, 08:21:28 »
Ah cool! But not exactly cheap if you want to replace all keys  :-X
The lego keys over at geekkeys seems pretty nice to type on, but way too expensive.
( http://www.geekkeys.com/holyoops-lego-aluminum-keycap/ )
Re: Hi, I'm new :)
« Reply #10 on: Thu, 07 July 2016, 05:27:05 »
Unfortunately as soon as you move away from ABS or PBT (or even POM) plastics, prices quickly escalate.
