Author Topic: Lexmark M15 Select-Ease rebuilding  (Read 3907 times)
Offline beemerburner
« on: Thu, 23 June 2016, 14:44:35 »
To all,
Back in the day I bought several Lexmark split keyboards.
Due to arthritis I can only use these keyboards. I am down to my last new one, after all these years.
QUESTION:
Is there anyone or any company that rebuilds these keyboards?
I think the problem I have on two or three of my old ones are the sensor contact sheets under the keys.
Any LEGITIMATE  leads for rebuilding would be appreciated.
Thank you,
Matt
Re: Lexmark M15 Select-Ease rebuilding
« Reply #1 on: Thu, 23 June 2016, 14:52:14 »
Phosphorglow might do it. His site is here. Super friendly guy, can't hurt to ask him at least.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Thu, 23 June 2016, 15:15:48 »
I have to wonder if Unicomp might have M15 parts sitting in a corner of a warehouse.  They do perform keyboard repairs (for standard M's).
You could try http://support.pckeyboard.com/ or support@pckeyboard.com.
Offline mike52787
  • Alps Aficionado
« Reply #3 on: Thu, 23 June 2016, 16:13:09 »
To all,
QUESTION:
Thank you,
Matt
Good luck getting these fixed, theyre very rare and sought after and finding parts might be tough.
« Last Edit: Thu, 23 June 2016, 16:14:41 by mike52787 »
« Reply #4 on: Thu, 23 June 2016, 19:39:57 »
Thank you for the replies.
I dealt with Unicomp back in the 80's and 90's. I called them this morning and was surprised that someone answered.
They said "no" to anything about M15s. NO parts, NO service, NO ideas, NO help.
He said to check a site called clicky something.......    Left an contact question there.
Will contact outfit suggested in this thread.
Thank you,    keep the recommendations coming.
Matt
PS ,    the CONSTANT "verification" questions are ASININE!
Offline bocahgundul
  • a seal
« Reply #5 on: Thu, 23 June 2016, 19:43:04 »
http://clickykeyboards.com/
Try contacting this one!
« Reply #6 on: Thu, 23 June 2016, 19:44:47 »
Just left a message with Phosphorus glow, as recommended above.
« Reply #7 on: Thu, 23 June 2016, 19:46:40 »
Left a contact message with them today. They are the outfit UniComp suggested I contact.
Offline Mattr567
« Reply #8 on: Thu, 23 June 2016, 19:49:24 »
Matt
clickykeyboards.com! They do all kinds of Model M restorations.
IBM P77, SKCC Green, 1984
Offline myxomicro
« Reply #9 on: Sun, 26 June 2016, 09:55:00 »
I had an M15. It worked fine. I still have the num pad for some reason.
I now use a Maxim Kinesis, which is pretty well built. I think the last one worked for 20 years.
Steve
Offline klennkellon
  • I like bottoming out
« Reply #10 on: Sun, 26 June 2016, 12:04:41 »
If all else fails Matias makes a solid ergonomic board with their Matias switches.
« Reply #11 on: Mon, 06 March 2017, 16:46:39 »
What a waste of time.
Have been trying to get ANY RESPONSE from Phosphorglow, to no avail.
Have been sending emails to them via their "contact us page" , once per month or two -  since June of 2016 BUT NO RESPONSE.
I ask if they can repair the split m15 boards.... I guess they don't want to answer or they are completely incompetent.
« Reply #12 on: Mon, 06 March 2017, 16:59:51 »
I think phosphorglow burned out of keyboards. It happens.
If you want your M15 fixed, you might wanna try asking around here and DIYing it yourself. That's the most efficient way to do it, which is why most of us DIY our boards.
If you want someone else to do it, check the subforum.
« Reply #13 on: Mon, 06 March 2017, 18:12:18 »
Think I need the contact sheets that the keypad presses against.
