Author Topic: Hello  (Read 4885 times)
Offline Swatman
Hello
« on: Fri, 24 June 2016, 19:16:03 »
I have been checking out this site for a few days now.  I have had a Steelseries 6g v2 for a few years now, and after seeing all of the great things you guys do with Mech Keyboards, I decided to pick up a TADA68.  I should get it hopefully mid August :).  I want to go for a Red and Black keycap theme.  Any suggestions where I can search for that?  Preferably with translucent lettering so that the backlit LED's can shine through.  Thanks!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hello
« Reply #1 on: Fri, 24 June 2016, 19:55:06 »
Hey there, welcome.
Can you understand the firmware programming page? I followed some links from the Originative Co. website and ended up with a GUI of what looks like a keyboard layout editor and a way to download the custom firmware output but all of it is in Chinese. I can translate with Chrome just fine but man that's a bummer to have to do.
Offline Swatman
Re: Hello
« Reply #2 on: Fri, 24 June 2016, 19:57:57 »
Hey there, welcome.
I haven't looked at the programming page yet.  That kind of scares me just reading your post haha.  Am i in for a bad time?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hello
« Reply #3 on: Fri, 24 June 2016, 20:11:06 »
Hey there, welcome.
I dunno, do you have any friends that can read Chinese? You'll be fine.. I think ;)
Offline Swatman
Re: Hello
« Reply #4 on: Fri, 24 June 2016, 20:48:51 »
Just looking to use it as a normal keyboard, how hard is it to setup?
Re: Hello
« Reply #5 on: Sun, 26 June 2016, 01:23:46 »
Welcome to Geekhack!
The TADA68 is a pre-built keyboard, right?  Just one that happens to be programmable?  Is there any particular reason you chose that one?
Some of the keycaps are not quite standard size, which will make a little more difficult to find replacement keycap sets, especially backlight-friendly sets.  I have see a few black backlight-friendly sets, but none in red, unfortunately.
Offline Swatman
Re: Hello
« Reply #6 on: Thu, 30 June 2016, 13:04:26 »
It looks like pretty normal keycaps to me??
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hello
« Reply #7 on: Thu, 30 June 2016, 13:54:21 »
Oh, I read somewhere that the PCB will work with TMK firmware. If that's the case you'll have access to full English instruction ;)
Re: Hello
« Reply #8 on: Sun, 03 July 2016, 01:37:05 »
Going by the images on this site, it looks like the bottom row is 1.25 1.25 1.25 6.25 1 1 1 - not every keycap set matches that, and you'd probably need a US ANSI base set + some 1x modifiers to complete a bottom row like that.
Plus the profile on some of the keys on the far right would not exactly match.  Page Up is usually the same profile as the number row, but on the TADA68 it should be the same as the ASDF row.  That wouldn't bother a lot of people, but quite a few people would really notice it.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hello
« Reply #9 on: Sun, 03 July 2016, 07:12:02 »
I think Geekkeys sells pbt keysets that work with most 75% keyboards. It will have that 1.75u Rshift and probably a few 1u modifiers.
Offline Swatman
Re: Hello
« Reply #10 on: Sun, 03 July 2016, 07:54:20 »
Thank you for the heads up on that.  I see it now
