Author Topic: Question for HHKB Pro users: Why is the bottom row off centered?  (Read 3981 times)
Offline ideus
  • Björkö.
Do you know the reasoning behind the off centered bottom row design?
Have you noticed any issue with it in your daily typing?
Do you perceived any advantage on having the space bar and mods in that positions?
Offline QuincyJones
Re: Question for HHKB Pro users: Why is the bottom row off centered?
« Reply #1 on: Sun, 26 June 2016, 09:45:31 »
It was cheaper to produce like this.
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline jacobolus
« Reply #2 on: Sun, 26 June 2016, 09:50:05 »
Yeah, it extends 2¾u to the left of the touch typing center (between G/H keys), whereas it extends 3¼u to the right. They should have shrunk the key down to 5½u or smaller, and pushed the right side inward a bit.
I assume the 6u spacebar was just the size they could find.
To be fair, the whole keyboard design extends too far to the right. Blame IBM.
« Last Edit: Sun, 26 June 2016, 09:58:39 by jacobolus »
Offline Polymer
« Reply #3 on: Mon, 27 June 2016, 03:10:06 »
Because a Centered Space bar means you're not pressing the center of the spacebar unless you hit the spacebar at "B"....and most people don't...and even less likely to do so in Japan.
It makes perfect sense IMO....and it is exactly where it should be...
« Last Edit: Mon, 27 June 2016, 19:49:00 by Polymer »
« Reply #4 on: Mon, 27 June 2016, 03:32:34 »
The bottom row is the same layout as Realforce, just with a few keys removed.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #5 on: Mon, 27 June 2016, 09:48:19 »
My IBM actually has it left of centre.
