Author Topic: Purple Zealio vs Cherry MX Clears  (Read 18929 times)
Offline TheInverseKey
  • You can run but you cannot hide!
« on: Sun, 26 June 2016, 10:04:26 »
Hi,
Just wondering what the main differences between these switches are.
Also other places that sell these switches besides Massdrop.
Thanks
Offline davkol
  •  Post Editing Timeout
Re: Purple Zealio vs Cherry MX Clears
« Reply #1 on: Sun, 26 June 2016, 12:00:41 »
Purple Zealio switches are clones of Cherry MX switches, manufactured by Gateron for ZealPC (which is the answer to your other question). They use lighter springs compared to genuine Cherry MX Clear; the idea originated from "ergo clear" modification many years ago. Cherry Corp. required very high MOQ, when they were asked to mass produce such switch configuration, thus it didn't work out back then.
In terms of technical differences (besides stock springs), gaterons (including zealios) have had significant quality/consistency problems, but they're regarded as smoother (zeolios come lubed out of the box too AFAIK) and usually have clear covers/housings.
« Reply #2 on: Sun, 26 June 2016, 16:02:47 »
Thanks
Offline ThoughtArtist
« Reply #3 on: Mon, 27 June 2016, 00:47:41 »
MX Clears have a special spring with spread out coils designed to match the larger tactile bump, force is not as flatly linear as other MX springs, so it's cushiony (light at top, heavy at bottom). Zealios have a plain spring (coils closer together like MX Red or Black) that bottoms out more sharply and feels more notchy since the flatter force curve doesn't accentuate the bump.
« Last Edit: Mon, 27 June 2016, 01:04:13 by ThoughtArtist »
Offline davkol
« Reply #4 on: Mon, 27 June 2016, 02:41:07 »
A switch (so-called "panda black") with a MX Clear's spring and a linear stem has linear action, only the coefficient is larger, thus the graph is steeper. Korean 78g have the same kind of slope AFAIK, and zealios are apparently available with these springs out of the box.
In that case, Purple Zealios are pretty much exact clones of OG MX Clears, except a bit lighter/smoother and transparent.
« Reply #5 on: Mon, 27 June 2016, 03:55:22 »
The purple Zealios are smoother than some genuine Cherry MX Clear stems that I have lubed and put into Gateron housings.
Offline zephyr11
« Reply #6 on: Mon, 27 June 2016, 09:40:56 »
woah,  really???
that got me REALLY interested!!!
hopefully i can still get it for a decent price.  :p
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline duhhey
« Reply #8 on: Tue, 28 June 2016, 17:50:15 »
Zealios are super smooth compared to stock clears
Offline zephyr11
« Reply #9 on: Tue, 28 June 2016, 20:33:04 »
just noticed something about the zelios switches.
that they are pcb mounted, I read that the additional 2 feets, can be cut, what do you use to cut them to make them plate mounted?
Offline Badwrench
  • ummmm.....I forgot
« Reply #10 on: Tue, 28 June 2016, 20:44:13 »
Flush cutters:
Hakko flush cutters
Offline zephyr11
« Reply #11 on: Wed, 29 June 2016, 21:04:42 »
Great!
Offline brighenne
« Reply #12 on: Thu, 30 June 2016, 13:23:46 »
He also has a plate mount version if you want 65g and don't mind the milky bottom.
Offline zephyr11
« Reply #13 on: Thu, 30 June 2016, 21:24:36 »
that's def even better option!
thanks!
Offline zephyr11
« Reply #14 on: Thu, 30 June 2016, 21:41:41 »
now just gotta wait for a flash sale or something, $100 for switches is a tad too much for me to dump in right now.  :eek: :eek: :eek: :eek:
« Reply #15 on: Fri, 01 July 2016, 12:40:04 »
Wow thanks guys for all of the info.
Offline brighenne
« Reply #16 on: Fri, 01 July 2016, 13:02:21 »
You're doing a full size board I take it? I'll have some leftover plate mounts that I'd be willing to sell at pre-order price ($.75/sw) but I'll only have ~65.
Offline zephyr11
« Reply #17 on: Sun, 03 July 2016, 22:59:13 »
PM incoming.  ;D
