Author Topic: List of Manufacturer of Mechanical Keyboard?  (Read 8889 times)
Offline wsxdr
« on: Mon, 27 June 2016, 23:02:16 »
Corsair, Logitech, Das, Deck, Ducky, Filco, and?
Offline klennkellon
  • I like bottoming out
Re: List of Manufacturer of Mechanical Keyboard?
« Reply #1 on: Mon, 27 June 2016, 23:11:05 »
If we're talking current keyboards:
KBParadise
Matias (matias switches)
Unicomp (buckling springs)
KUL
Topre (topre)
PFU (hhkb)
Leopold
Noppoo
Keycool
Royal Kludge
There's more I don't remember off the top of my head.
Offline Bigpock
« Reply #2 on: Mon, 27 June 2016, 23:48:17 »
Razer blackwiddow with rgb backlighting
Offline y11971alex
  • Looking for Toronto meetup
« Reply #3 on: Tue, 28 June 2016, 00:00:21 »
Active manufacturers: Rapoo, Nappoo
Non-active manufacturers: IBM, Univac/Unisys, DEC, Amdahl... basically any big computer firm made their own keyboards.
Early computers didn't have industry standards (apart from IBM's 80-column card) as far as I know, so each computer could only use the keyboard it shipped with or some very similar models from the same manufacturer.
If you plug this:
into this:
Both will probably explode in a cloud of expensive fireworks.
Incidentally, the bank of switches on the control panel to the lady's right is actually the "keyboard" of the IBM 709.  You use it to input a 32-bit binary word into a selected memory address, which probably means it has the most direct input method ever, directly editing a memory location.  I wonder if that is considered "mechanical" enough... :D
« Last Edit: Tue, 28 June 2016, 00:22:33 by y11971alex »
Offline KnivesM
« Reply #4 on: Tue, 28 June 2016, 00:13:37 »
Cooler Master, Steelseries, WASD
Others
Offline supamesican
« Reply #5 on: Tue, 28 June 2016, 07:56:39 »
man that univac board looks like it would be fun to use
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #6 on: Tue, 28 June 2016, 08:26:59 »
Do manufacturers with only one model count? If so, then ErgoDox EZ and keyboardio.
There's also Kinesis Corporation, and Maltron, both with some variety of models.
Offline Muted
« Reply #7 on: Tue, 28 June 2016, 13:12:14 »
Ultimate Hacking Keyboard, Truly Ergonomic Keyboard, Type Heaven, Vortex, Realforce,  Redragon, Rosewill, Adesso.
Offline keyladding
« Reply #8 on: Tue, 28 June 2016, 13:23:15 »
Deck and Logitech
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #9 on: Tue, 28 June 2016, 14:06:29 »
Now that the Cherry patent expired, there are literally hundreds of independent manufacturers vying to get into the scene so the field of manufacturers has changed massively, even from just last year. Just search Taobao and you'll see mechanical keyboards from companies you've never heard of like Lingyi, GANSS, or WolfBlaze.
Offline davkol
  •  Post Editing Timeout
« Reply #10 on: Tue, 28 June 2016, 16:52:51 »
ITT people confusing brands and manufacturers.
Offline klennkellon
« Reply #11 on: Tue, 28 June 2016, 21:03:27 »
The Realforce and TypeHeaven are actually just names for Topres own keyboards.
Offline davkol
« Reply #12 on: Wed, 29 June 2016, 05:55:59 »
Yeah, and for example Das is actually a product line of Metadot, and the products themselves have been made by various manufacturers (Key Tronic, Cherry Corp., Costar, another one or two OEMs).
Offline SBJ
  • Tactile pls
« Reply #13 on: Wed, 29 June 2016, 07:14:39 »
Varmilo makes keyboards, and they have a forum on here: https://geekhack.org/index.php?board=192.0
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Wed, 29 June 2016, 08:02:17 »
Xerox
Offline Lepidus
« Reply #15 on: Wed, 29 June 2016, 08:15:45 »
This. Most of the brands posted here only order, design or rebrand stuff.
Costar, iOne, SolidYear, Togran, TG3, Datacomp, i-Rocks, ZHH are a few examples of actual manufacturers.
