Author Topic: Cherry MX White Switch review  (Read 8201 times)
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« on: Tue, 28 June 2016, 09:22:39 »
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline UnFocused
Re: Cherry MX White Switch review
« Reply #1 on: Wed, 29 June 2016, 22:17:08 »
Have you considered doing a review of current MX blacks vs vintage ones as found in something like a 1980's Wyse terminal keyboard?
After using MX blues for a few years, MX clears for about 6 months, briefly using MX browns and reds, vintage MX blacks have become the only Cherry switch I care about. I absolutely love these switches.
« Reply #2 on: Thu, 30 June 2016, 05:06:57 »
I'd love to eventually but i'd need to get my hands on a board with Vintage blacks first and use it for awhile by comparison.  Might be something good to look for on Ebay one day next time i have the funds to go on a spending spree.
Offline UnFocused
« Reply #3 on: Thu, 30 June 2016, 07:50:30 »
Many of the Wyse boards on eBay are overpriced, but there are some good finds every now and then. I bought one recently without a case for $14 something. It had a 1986 date code on the board so I knew it was full of vintage switches and not a mix as tends to happen as you get into the 90s. I built a Phantom with its switches.
Offline dante
« Reply #4 on: Thu, 30 June 2016, 07:54:30 »
This will sound crazy - and maybe I've only had good luck but if you are out there in the wild (goodwill, etc...) and you spot a tte meka G1 give it a try because it had seriously smooth mx blacks for a modern board.  I've tried 3 different copies and always smooth.  Not even the WASD V1 which was a clone of it felt as smooth for some reason.
« Reply #5 on: Thu, 30 June 2016, 17:24:19 »
Most Thrift stores like those near us if you are lucky have Dell QuietKey Rubberdomes.  The few who spot mech boards worth a damn put them in cases and charge near new.  IE a local thrift store had a Das board for $100.
