Author Topic: JD40 MKII, 2016  (Read 90081 times)
Offline mteinum
JD40 MKII, 2016
« on: Tue, 28 June 2016, 17:17:01 »
Hi,
I've always wanted a JD40 from the first time I saw one, and when the PCB was dropped at techkeys.us - I had to have it. And now it's here  ;D.
JD40 by Morten Teinum, on Flickr
Pictures of the first (?) PCB have the following layout
140933-0
R1: 12
R2: 11
R3: 11
R4: 6
Total 40
Looks like there is a change in MKII with
R1: 12
R2: 11
R3: 11
R4: 10
Total: 44
From the reddit thread:
https://www.reddit.com/r/MechanicalKeyboards/comments/4p2tls/buying_jd40_techkeys/
This should be possible:
140935-1
Have any of you built it this way?
Offline MajorKoos
  • 1 life please. Extra large.
Re: JD40 MKII, 2016
« Reply #1 on: Sun, 03 July 2016, 07:47:00 »
I've just tried this layout - unfortunately not all keys are registering at the moment - need to figure out how to remap them via easyavr I guess.
Re: JD40 MKII, 2016
« Reply #2 on: Sun, 03 July 2016, 07:54:51 »
Can you take pics of both sides of the PCB?  Should be easy to add the extra positions which aren't currently visible.
edit:  Unless it's called the JD45 in EasyAVR, that looks close but I thought it was a completely different board....
« Last Edit: Sun, 03 July 2016, 07:59:09 by suicidal_orange »
Offline MajorKoos
Re: JD40 MKII, 2016
« Reply #3 on: Sun, 03 July 2016, 09:45:03 »
Success!
I created a keymap with the missing keys in it.
 - Stick it in C:\Users\%username%\.EasyAVR\Boards
 - Then create a new keymap using the JD40 MkII keymap as a base
Now to print a decent set of keycaps for it.
Offline a-c
Re: JD40 MKII, 2016
« Reply #4 on: Tue, 05 July 2016, 14:10:17 »
Also built mine this way.
Thinking of swapping the right shift.
Running QMK. http://www.40percent.club/2016/07/ivory-jd40.html
Offline rumo
Re: JD40 MKII, 2016
« Reply #5 on: Wed, 12 October 2016, 05:11:09 »
Is it possible to put long spacebar on MKII like on v1?
Offline a-c
Re: JD40 MKII, 2016
« Reply #6 on: Wed, 12 October 2016, 22:47:45 »
Yes, the MKII PCB supports the original layout. http://www.40percent.club/2016/07/jd40-woody.html
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: JD40 MKII, 2016
« Reply #7 on: Mon, 25 March 2019, 16:58:16 »
I know this post is old but where are the keycaps from?
Just my thoughts
Offline HPE1000
  • Keycap Paparazzo
Re: JD40 MKII, 2016
« Reply #8 on: Mon, 25 March 2019, 17:01:59 »
It is these, but it looks like they might have stopped offering dyesub ones outside of group buys so you can only get blanks.
https://pimpmykeyboard.com/g20-blank-keysets/
Offline Sintpinty
    • My Roblox Profile
Re: JD40 MKII, 2016
« Reply #9 on: Mon, 25 March 2019, 17:11:59 »
Thx :D
Just my thoughts
