Author Topic: [Help] Poker Pro firmware problem.  (Read 4196 times)
Offline boyswat
« on: Wed, 29 June 2016, 14:37:51 »
Hello,
I have a Poker Pro model PKX-6100, date: 2016-02-25. After I flash the Poker's firmware in order to use the N roller key, the programming functions on the keyboards has stopped working. The LED on the right side of the space bar still work when programming, but the programmed keys does not work after exiting program mode. When entering Toggle mode, the keyboard stopped working, and I had to unplug the cable and plug it back in for the keyboard to work again. The current firmware of the keyboard is S2075V15 according ikbc-USB Updates. I check a different Poker Pro and it's firmware is S2132V22.
I need firmware S2132V22 pls post if u have, thank you
My pcb:
