Author Topic: Making the switch  (Read 2364 times)
Offline Ziggy4H
Making the switch
« on: Thu, 30 June 2016, 07:59:36 »
When did you decide to go from a full size keyboard to a tenkeyless or even smaller like an HHKB or 60%?
I am contemplating going smaller and wanted to know for a work keyboard is it a problem?
Offline Polymer
Re: Making the switch
« Reply #1 on: Thu, 30 June 2016, 08:56:31 »
Most people can go without the 10 keypad...Depending on what you do for a job, there's a good chance you have a laptop without a numberpad which probably made it easier for people to adjust..but the reality is, unless you're doing heavy numbers work, you don't need the 10 keypad.
Going without dedicated arrow keys will be a bigger jump, IMO...and why some of these other slightly bigger than 60% layouts are also popular...
Even if for some reason I needed to start doing heavy numbers work, I'd just buy a dedicated numberpad....the TKL or smaller form factors are so much better I'd hate to go back to full..
Offline Dan_Chytil
« Reply #2 on: Fri, 01 July 2016, 02:55:33 »
I think TKL + dedicated numpad if needed is the way to go.
I love the smaller form factor of 60/65% but there are a lot of compromises to be made if you use keyboard shortcuts - even a common alt + f4 becomes alt + fn + f4
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #3 on: Fri, 01 July 2016, 04:30:01 »
I have never liked Fullsize boards honestly because unless your job requires it...honestly i don't see the point.  Even should your job require it an external numpad is vastly superior IMO being able to move it where you like giving more space for your mousing arm.  Myself i am fairly proficient with the number row anyways...however should i be doing a large amount of math i do have an external Kinesis Numpad next to my HHKB for when i do Taxes or formulate recipe costs etc.  That said far as switching sizes i started with TKL size...found in my usage i never really used F keys or anything a TKL offers..so went down to 60% and been there ever since with multiple in my collection now.  A TKL or larger just makes my desk feel cluttered now and i can't stand not having a 60% at this point. Even for gaming i have come to prefer 60% over TKL as the extra space and bringing your arms closer together while using a mouse at the same time is far more ergonomic (especially over a full size).
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Fri, 01 July 2016, 04:56:56 »
An external numpad would take up even more space. Besides, I use the numpad so often there's no point in me moving it around :p .
« Reply #5 on: Fri, 01 July 2016, 15:36:09 »
You have explained (quite well) why the numpad is essential for your job and of course those jobs get a bit of a pass.  I doubt there is much you do that uses the mouse while typing at the same time.  However for those of us that do the distance apart between your mousing hand and typing hand (Primarily gaming of course) is exceptionally not ergonomic and very uncomfortable.  Also the difference in an external numpad is
A. I can put it away when i do not need it, which frankly is more often than not.
B. It gives me another place to put Artisans or spare caps :p
C. an External Numpad next to my HHKB is right on par the same size as my TKL KUL 87 board is and loads smaller than a Fullsize for sure.
D. Without modification it allows me to have different switches on my numpad than my keyboard.  I highly prefer clickly tactile on the numpad for doing quick math where as for constant typing i prefer my HHKB or MX Clears as the noise of Clicky tactile can bother me over long periods of time.
Even were i in a position were constant access to a numpad was more or less a necessity such as your line of work i would still prefer a 60%+ ext numpad.  Or if the Function row was also a requirement a TKL+ Ext numpad so i could move it to the left out of the way when not needed.  In addition it just feels more "natural" to me on the left than on the right side.
It is of course exceptionally subjective and while i totally understand someone preferring a fullsize for myself it's just loads of uncomfortable and wasted space.
We aren't all chemists after all :p
The only time i need a numpad at work is when figuring out costs of new recipes or sending out orders online for bulk ingredients or figuring out profit % etc which generally is only 1-2 days a week.  I would rather not have that extra space wasted the rest of the time by something i don't need at the moment.
« Last Edit: Fri, 01 July 2016, 15:47:10 by LiquidEvilGaming »
Offline klennkellon
  • I like bottoming out
« Reply #6 on: Fri, 01 July 2016, 18:36:51 »
I like TKL because I like being able to use the function keys without a layer and occasionally like to use print screen, not having a numpad saves a lot of mouse space and is more ergonomic for me.
I do use the numpad sparingly, usually just basic calculator problems.
Offline FoxWolf1
  • 154
« Reply #7 on: Sat, 02 July 2016, 12:09:30 »
When? Never. If anything, I went the other way. Spent many years doing 99% of my computing on laptops without numpads and came away from that quite determined to get my numpad back ASAP upon switching to standalone keyboards.
Personally, I don't have any problems with the ergonomics of a full-size keyboard. Then again, as a 6'3", broad-shouldered, trackball user, I can have a much wider keyboard than others and still never encounter the situation where I feel like I have to reach my hand way off to the side for anything.
Offline jcoffin1981
« Reply #8 on: Mon, 04 July 2016, 23:05:42 »
The number pad can be placed behind the board and not interfere with the use of the mouse.  My elbows and shoulders are more comfortable since switching to a 60% form factor.  The built in arrows are easy to use.  I would only miss the keypad if I had to type a long string of numbers.
