Author Topic: Kensington Slimblade Buttons "sticking"  (Read 9525 times)
Offline coolspot
« on: Thu, 30 June 2016, 18:16:56 »
Hi all,
I see that there is a common complaint that the buttons on the Kensington Slimblade then to "stick" - if you don't press a particular button for a while, it requires extra force to press down. I find this behaviour very annoying.
Has anyone found a fix for this problem - are there any mods to make the Slimblade buttons smoother so they don't stick from time to time?
Offline davkol
  •  Post Editing Timeout
Re: Kensington Slimblade Buttons "sticking"
« Reply #1 on: Fri, 01 July 2016, 02:59:31 »
My disassembly pics.
The buttons act as levers, thus you should be pressing them above switches or as close to their edges at 9/3 o'clock as possible to minimize force. If they grind or stick, it's probably because the upper part of the case (with buttons) is misaligned.
Offline coolspot
« Reply #2 on: Tue, 05 July 2016, 17:52:14 »
Left mouse button is fine, but all the other buttons seem to stick from time to time - what I mean by that is that it will require extra force to push and then it will "click" back into place - for a while, until I change buttons.
So I guess only fix is to disassembly and realign?
Offline davkol
« Reply #3 on: Wed, 06 July 2016, 02:46:18 »
Yes.
