Author Topic: Maltron 3D ‑ Manufacture  (Read 6328 times)
Offline bibidibop
« on: Fri, 01 July 2016, 05:49:05 »
Hi everyone,
Where is the Maltron 3D manufactured (“made in”) ?
« Last Edit: Fri, 01 July 2016, 11:07:13 by bibidibop »
Offline bibidibop
Re: Maltron 3D ‑ Manufacture
« Reply #1 on: Fri, 01 July 2016, 11:05:08 »
They answered me the keyboards are manufactured in Stafford, UK.  :thumb:
We better understand the price then: people get decently paid for the work!
Offline hoggy
  • * Moderator
« Reply #2 on: Sat, 23 July 2016, 13:39:19 »
They're hand made, and the design requires that the switches are wired in by hand.  They even add their signature to the inside of the case.  This means that they aren't cheap.
However, if you have a specific requirement, such as brown switches, or a particular key map, or even a one-off case they are happy to help.
You can rent a board off them for a while if you're not sure.  You can get hold of them on ebay uk, but they can be quite beaten up.  Tell tale signs include square holes in the case (missing a switch).
