Author Topic: Looking for keycap set  (Read 3268 times)
Offline ploooopp
  • My personal text wouldn't fit. This will do.
« on: Sat, 02 July 2016, 02:00:26 »
Hi guys, I'm wondering if there's a black SA keycap set that's either black and bronze or black and gray. Thanks in advance! (if there isn't a black and bronze one, someone should make it.)
So... I can put anything here?
Offline seville57
Re: Looking for keycap set
« Reply #1 on: Sat, 02 July 2016, 05:42:04 »
Should it be in ISO/Nordic or ANSI layout?
Signature Plastic/Pimp my k-board are the only one that makes SA keycaps sets (that I know).
You could always contact them but I think the keycaps set you want is not gonna be cheap: http://pimpmykeyboard.com/contact-us/
« Last Edit: Sat, 02 July 2016, 06:01:45 by seville57 »
Offline Scivive
« Reply #2 on: Sun, 03 July 2016, 05:15:41 »
Try the filco doubleshot SA, brown so dark it looks black
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Sun, 03 July 2016, 11:52:22 »
I'm pretty sure keyboardco.com will ship to your location. You might even find a 105 Swedish layout of the Filco Double Shot SA keyset (the same one scivive mentioned in the previous post). That site has a bunch of different language formats for that keyset. The USA 104 layout is out of stuck atm :(
http://www.keyboardco.com/product/double-shot-filco-105-key-swedish-finnish-keyset.asp
Dark brown from everyone is saying. (SP/PMK swatch is TAA)
