Author Topic: where to buy Kailh switches in Europe?  (Read 3656 times)
Offline Naweo
« on: Sat, 02 July 2016, 05:54:25 »
Hey!
I wanted to stock up on kailh switches. Specifically the ones with the housings matching kailh red switches.
would kailh black switches use the same housing as kailh red switches? Maybe linears and non-linear switches uses the same housing?
I found some boards on amazon.co.uk, but not sure they are legitimate.
Is it possible to buy kailh switches seperately somewhere?
Offline Mechboards
  • Mechboards UK
    • Mechboards
Re: where to buy Kailh switches in Europe?
« Reply #1 on: Thu, 12 January 2017, 04:37:30 »
Hey Naweo,
Sorry for the really late reply. I can bulk buy these for you if you're still interested?
Offline need
« Reply #2 on: Thu, 12 January 2017, 05:19:23 »
Why are you necroposting a 6 months old post...?
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #3 on: Thu, 12 January 2017, 20:06:29 »
It's called efficiency because starting up another thread is not only useless but not necessary at all.
Nothing worse than having hundreds of threads describing the same question or inquiry over and over again.  Far better to keep it down to the bare minimum for users to access at any time.
Offline need
« Reply #4 on: Fri, 13 January 2017, 06:48:42 »
I think making a new thread makes most sense, as the OP surely has obtained what he want by this point (6months!) and someone just pops up offering switches to them?
In some cases I do agree with you in terms of efficiency, but it just doesn't really apply to this case.
Offline alienman82
« Reply #5 on: Fri, 13 January 2017, 13:51:51 »
removed.
« Last Edit: Thu, 01 March 2018, 13:22:26 by alienman82 »
Offline JDragon
« Reply #6 on: Fri, 13 January 2017, 16:44:55 »
Somewhat related - does anybody know how to source Kailh SMD switches? Can't find them anywhere.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #7 on: Wed, 18 January 2017, 08:57:28 »
Are you looking for RGB Kailh switches?
I understand it's crazy as it's 6 month old, but just trying to help out a user. I have no need to open a new thread.
