Author Topic: DIY wooden tenkeyless keyboard  (Read 7290 times)
Offline exia
« on: Fri, 01 January 2010, 20:02:04 »
found this on google: http://woodgears.ca/computer_case/keyboard.html
what do you think?
wood+electronics don't match
Offline ricercar
  • mostly abides
« Reply #1 on: Fri, 01 January 2010, 21:02:43 »
I think that's nice, but it needs a matching mouse. And the wood needs to be darker.
A while back webwit posted an oval wooden keyboard pic similar to the OP. It jump-started me to begin oiling a wooden cutting board for use with a metal plate from kishy's 101 non-Cherry blacks that I'm making tenkey-less. A small cutting board is easy to work with, offers room for a palm rest, and is easily replaced if the project goes awry.
I'll cut an opening for the alpha block keys to come through, mount the plate on the bottom. Exposed point-to-point wiring might be a problem, but I'll solve that if I like how it looks.
« Last Edit: Fri, 01 January 2010, 21:09:05 by ricercar »
Offline Mental Hobbit
« Reply #2 on: Sat, 02 January 2010, 00:59:05 »
With plastic keys it looks crappy. And wooden keys would be impossible to keep clean I guess.
Typing on blues.
Offline sixty
    • http://deskthority.net
« Reply #3 on: Sat, 02 January 2010, 10:01:33 »
Don't like the looks of the one in the OP much.
Much nicer.
and..
Much nicer again!
Offline ricercar
  • mostly abides
« Reply #4 on: Sat, 02 January 2010, 14:20:01 »
Those last two are mighty sweet. I'm going back to the drawing board on my project.
Offline exia
« Reply #5 on: Sat, 02 January 2010, 16:27:32 »
Quote from: sixty;147284
Much nicer.
and..
Much nicer again!
cutting board keyboards?
Offline msiegel
« Reply #6 on: Sat, 02 January 2010, 17:12:01 »
Quote from: ripster;147367
You're not a Art Major?
maybe culinary :)
