Author Topic: Kinesis Advantage Instant Configuration Settings  (Read 1370 times)
Offline ni_soros
« on: Sun, 03 July 2016, 11:38:38 »
Hello,
I reset my Kinesis Advantage twice using Progrm + Shift + F10 and the instant configuration settings with =w, =p, =m, and well as all the other =* functions were no longer working.
I then did the F7 reset while rebooting the computer and nothing seemed to change. The lights were flashing, indicating a successful reset, after each try, so I don't think that it was a problem with the way I did the reset.
I did this on an Ubuntu Linux PC, and then on a Windows 10 PC. No difference in either case.
Below is technical information. I am new to the forum, so please tell me if there is anything that I am missing. I hope someone can give me some insight into this issue. Thanks in advance.
Kinesis Advantage MPC USB/QD
Manufactured in 2002
Model #: KB500USB/QD
Offline QuincyJones
Re: Kinesis Advantage Instant Configuration Settings
« Reply #1 on: Sun, 03 July 2016, 15:14:31 »
hi, advantage have awesome technical support - email them monday and ask
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
