Author Topic: b.mini x2 questions  (Read 3024 times)
Offline impsy
b.mini x2 questions
« on: Tue, 05 July 2016, 22:31:22 »
basically I want to make this keyboard but with red instead of pink : https://imgur.com/a/mPgTc#zOPUgcl
winkeyless guy sent me email with this list: http://i.imgur.com/8XWA6NX.png
I guess I just have to change led to red and whatnot seems fine?
Also I am a complete noob at these things, is it possible to get the keycaps in these pictures the same but in red instead of pink on the spacebar/korean lettering as well? I saw on reddit that people pointed towards a post here to get those not sure if its still possible or if there is a site that will custom make them etc.
Last question I have is if I buy all this stuff most of it is supposed to come pre-assembled right? How much manual work will I have to do to get things working because I have 0 idea on how to solder or do anything of the like, I was under the impression most of it is pre-assembled as I would select that option.
Thanks in advance
Offline impsy
Re: b.mini x2 questions
« Reply #1 on: Wed, 06 July 2016, 10:40:21 »
bump
Offline tacnificent
« Reply #2 on: Wed, 06 July 2016, 10:42:53 »
The LEDs on the bottom are RGB. The color can be picked using the bootmapperclient you download. If you're talking about the in-switch LEDs, you can specify them to be red through the drop down menu.
The keycaps I don't know about specifically but if they were part of a group buy or limited run, chances are unlikely you'll be able to get them; soon if at all unless someone is willing to sell you their set. Usually something specific like that aren't available "off the shelf"
The soldering services that Houjin typically offers is for the advanced soldering of the little SMD components such as the controler, diode, resistor and RGB LEDs. You would still need to do the (much easier) through hole soldering of the switches and the in-switch LEDs usually.
However, from the email he sent you, it seems like he's willing to do that soldering for you as well so when it arrives, it will be completely assembled and all you'd need to do is find keycaps.
If you agree, he'll send you an updated invoice which includes all the soldering fees and parts needed for a complete ready-to-go keyboard.
The choice becomes whether or not you want to learn to solder. If you don't, then go with the additional services he's providing. If you do, there are many how-to's on youtube that will get you going.
If you care to see, you can view my build log of a b.mini. X2. The only thing I opted for him to do was the controller. The rest, diode, resistor and RGB stuff I did myself.
Offline DavidNZ
« Reply #3 on: Wed, 06 July 2016, 10:45:27 »
I have those keycaps, they come from this thread https://geekhack.org/index.php?topic=78563.0. The Korean keys only come in that colour.
Offline impsy
« Reply #4 on: Wed, 06 July 2016, 10:49:23 »
Ahh now I understand what he was trying to get at on the email, thanks for the information.
Do you know if I buy a custom keycaps set from WASD Keyboard and then maybe buy a few single custom pieces for the off pieces from the site as well that everything will fit the board? I'm assuming all keycaps are the same size really aren't they except the odd shifts etc right? If so i'll use the template and make my own set using like the 87 set cherry custom and whatever else ill need.. Just because I want to order everything at the same time..
Are they lower quality then the ones from the threads here?
Offline tacnificent
« Reply #5 on: Wed, 06 July 2016, 12:11:03 »
It should fit depending how you have the b.mini configured. Most sets will have 1.25u CTRL, ALT and WIN with a 6.25u spacebar and not a 1.5u CTRL and ALT with a 7u spacebar and no winkey.
Offline impsy
« Reply #6 on: Wed, 06 July 2016, 13:01:55 »
uh so in terms of layout I should go for the top spacebar layout for maximum compatibility?
And then looking at that picture all else I should have to buy is 1 custom right shift and maybe some other stuff? not sure
looking at wasd keyboard layout
