Author Topic: Can I get a year estimate on this Model M?  (Read 8770 times)
Offline QuincyJones
« on: Wed, 06 July 2016, 18:50:51 »
- UK layout,
- silver label with darker grey "IBM" in top right of the keyboard
- without lock lights
- AT connector
- Double sized '+' key in numpad (like on modern-day keyboards).
Any other indicators that I'm missing?
My estimate would be 1986 / 1987?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline mike52787
  • Alps Aficionado
Re: Can I get a year estimate on this Model M?
« Reply #1 on: Wed, 06 July 2016, 18:59:51 »
somewhere between 85-88, I think its a terminal board, probably the UK equivalent of a 1390120. It has extra wire stabs under the large numpad keys.
Offline QuincyJones
« Reply #2 on: Wed, 06 July 2016, 19:05:03 »
Thanks, do the earlier versions have a better build quality than the later IBM (non Lexmark) versions? Does this make it more valueable?
(please like me)
Offline mike52787
  • Alps Aficionado
« Reply #3 on: Wed, 06 July 2016, 19:07:09 »
absolutely! the early ms have a different feel, sound and weighting due to tighter tolerances, thicker back plates, and just all areound better build quality. I will record a little comparison between a 1998 maxi switch M and my 1987 1390131 and post it here.
Offline QuincyJones
« Reply #4 on: Wed, 06 July 2016, 19:13:20 »
wow - nice, thanks!
I'm not sure if I should buy one, it's fairly expensive. I guess, I could always sell it fairly easily if it wasn't for me.
(please like me)
Offline klennkellon
  • I like bottoming out
« Reply #5 on: Wed, 06 July 2016, 19:41:26 »
wow - nice, thanks!
The Model M's buckling springs are considered at least the third best clicky "switches" (it's technically a mechanism) after the capacitive buckling springs on the older Model F and SKCM Blue ALPS. If you like clicky switches you'll probably love the Model M.
Offline mike52787
  • Alps Aficionado
« Reply #6 on: Wed, 06 July 2016, 19:47:55 »
I would put skcm whites on the same level as a regular M.
Offline klennkellon
« Reply #7 on: Wed, 06 July 2016, 19:54:50 »
 I always found that the comparison between SKCM White and SKCM Blue was parallel to the Model M vs the Model F.  ;D
Offline QuincyJones
« Reply #8 on: Wed, 06 July 2016, 20:08:23 »
did all the earlier m's have a speaker underneath?
(please like me)
Offline klennkellon
« Reply #9 on: Wed, 06 July 2016, 20:11:25 »
later ones could too, but all model M's have the grille at least, until Unicomp took over.
Offline mike52787
  • Alps Aficionado
« Reply #10 on: Wed, 06 July 2016, 20:13:34 »
As promised.
Btw I just picked up that typewriter and havent got around to cleaning it up. It is absolutely disgusting.
Offline QuincyJones
« Reply #11 on: Wed, 06 July 2016, 20:14:34 »
when did lexmark take over production? was it mid 90s? Relating to what I asked earlier, are the very early model m's better than the latter ibm keyboards that were made before lexmark took over? also, does the production location make any difference? as this is a uk layout, i'm assuming it's from Scotland
(please like me)
Offline mike52787
  • Alps Aficionado
« Reply #12 on: Wed, 06 July 2016, 20:20:04 »
Well, from what I have seen the first lexmark ms were made in late 93 to early 94. The latest M that I have owned other than that maxi switch M13 was a 91 1391401. There was a noticable difference between the 0131 and the 1401, and there is a huge difference between the 0131 and the maxi switch. I cant really help you with the production location question, all my Ms are made in USA except the Maxi switch which is made in mexico. I have nothing of a similar date to compare the maxi switch with, and for all I know all late ms could feel like it. In short, early Ms feel alot better than later Ms.
Offline emdude
« Reply #13 on: Wed, 06 July 2016, 20:34:43 »
I believe Lexmark took over production from IBM around 1991, Lexmark-branded Model Ms did not appear until a few years later, as mike52787 has mentioned.
Current drivers: IBM Model M SSK
Offline y11971alex
  • Looking for Toronto meetup
« Reply #14 on: Wed, 06 July 2016, 20:44:47 »
I can't tell the difference between a 1390131 and a 1391401, for the record, and it is highly unlikely that their production differences are any more prominent than the conditions in which they are present.
Offline mike52787
  • Alps Aficionado
« Reply #15 on: Wed, 06 July 2016, 20:47:11 »
I can, maybe my 1401 was really well used though. the 131 felt snappier and had a deeper click.
Offline y11971alex
« Reply #16 on: Wed, 06 July 2016, 20:49:53 »
But your 131 is bolt modded! :eek:
Offline mike52787
  • Alps Aficionado
« Reply #17 on: Wed, 06 July 2016, 20:50:52 »
lmao so was my 1401
Offline y11971alex
« Reply #18 on: Wed, 06 July 2016, 20:53:31 »
lmao so was my 1401
Are the bolts punched into the same places on both keyboards?  Are they tightened to the same degree?
Offline emdude
« Reply #19 on: Wed, 06 July 2016, 20:55:40 »
Well, fohat has said something like this before and I also speak from experience: No two Model Ms feel nor sound exactly the same, even within the subset of a particular P/N.
I've heard of some people preferring Lexmark Model Ms for being snappier, presumably because they are younger and less used?
Offline mike52787
  • Alps Aficionado
« Reply #20 on: Wed, 06 July 2016, 20:56:53 »
well the 1401 was done by me, and the 131 was already done when I bought it. of course the screws were in the same place, the holes in the plate are the same. We used different size screws, but I tightened up the 1401 to my liking. not saying the 1401 was bad, just saying I saw an improvement.
Offline mike52787
  • Alps Aficionado
« Reply #21 on: Wed, 06 July 2016, 20:59:29 »
all 3 of the 1401s ive bolt modded felt the same after being modded. I cant speak for them before being modded, as soon as I got them I tore them down. They have been sold to 3 happy customers now, so I cant compare them directly though.
Offline klennkellon
« Reply #22 on: Wed, 06 July 2016, 21:20:43 »
Unicomps feel just as good as original Model M's from what I have tried, but brand new Unicomps are quite stiff so it gives the impression they feel more like the M2 out o the box.
« Reply #23 on: Wed, 06 July 2016, 21:31:38 »
« Last Edit: Wed, 06 July 2016, 21:33:44 by fohat.digs »
- Plato
Offline QuincyJones
« Reply #24 on: Wed, 06 July 2016, 21:34:07 »
so uhm, do terminal model m's (not the 122 variety) use scancode 2 and will just work with a normal at -> ps2 converter -> usb adapter?
(please like me)
Offline klennkellon
« Reply #25 on: Wed, 06 July 2016, 21:54:46 »
most terminal Model M's use either an RJ-45 connector or a right-angled connector that looks like AT but is not, you'll need to buy a Soarers Converter to get it to work.
Offline QuincyJones
« Reply #26 on: Wed, 06 July 2016, 23:04:35 »
https://en.wikipedia.org/wiki/Model_M_keyboard
Go to "Part Number" show
apparently it's a 1389969 from IBM UK, 1986 which I can't find anything about! Is that a good or bad sign?
(please like me)
Offline klennkellon
« Reply #27 on: Wed, 06 July 2016, 23:29:37 »
* has removable keycaps
* detachable cable
* XT/AT compatible
* No Lock Lights
* 1986
* ISO layout
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #28 on: Thu, 07 July 2016, 02:57:16 »
Yeah, should be a 1389969 from around 1986. I added that entry quite recently as a matter of fact. It's a rare part number, in fact silver badge UK Ms are pretty rare to begin with. I only found out the AT one's part number very recently, and then only using extrapolation. I don't have one yet, myself, even.
Offline QuincyJones
« Reply #29 on: Thu, 07 July 2016, 06:23:19 »
If you had to guess a price? Also where's hte cheapest place in UK to get a nut driver to open the bloody thing?
« Last Edit: Thu, 07 July 2016, 06:30:12 by QuincyJones »
(please like me)
Offline chyros
  • a.k.a. Thomas
« Reply #30 on: Thu, 07 July 2016, 07:26:25 »
Generally I charge £40 plus shipping for a good or excellent-condition '1406, tested working, hand-cleaned case and caps, and often without a cable (because they're detachable most don't come with them). I provide pictures of the rivets as well and report how many have broken off. At £40 plus shipping they go fast. Longest one has ever lasted was just under a week, but most of them went in a day or so. I'd expect silver-badge ones to fetch slightly more.
Offline QuincyJones
« Reply #31 on: Thu, 07 July 2016, 07:30:26 »
by "slighly more" you mean? £1 / £5 / £10?
(please like me)
Offline supamesican
« Reply #32 on: Thu, 07 July 2016, 07:56:31 »
Beam spring are kinda clicky aren't they ? :P
« Reply #33 on: Thu, 07 July 2016, 08:05:27 »
In the US it is easier to find a socket than a nut driver. Go to an auto parts store and be sure to get one that is "long" and "thin-walled"
5.5mm is a near-perfect substitute for 7/32"
- Plato
Offline chyros
  • a.k.a. Thomas
« Reply #34 on: Thu, 07 July 2016, 09:07:25 »
I think you should be able to shift it very quickly if you ask £50 for the whole thing, cleaned and tested. The cable itself should be worth a tenner at least.
Offline y11971alex
« Reply #35 on: Thu, 07 July 2016, 11:58:18 »
Chyros,
I heard from your videos that you are selling key caps; would you mind disclosing where are you making the sales?  I am looking for a set lately myself.
Best Regards,
Offline chyros
  • a.k.a. Thomas
« Reply #36 on: Thu, 07 July 2016, 12:14:41 »
Chyros,
Best Regards,
I just sell through classifieds. Send me a PM with what kinds of keycaps you're interested in and we'll talk shop :) .
Offline klennkellon
« Reply #37 on: Thu, 07 July 2016, 14:50:36 »
Yes but beam springs are hard to find, unreliable, and very difficult to get working on a modern system, so I usually don't bother talking about them when comparing them to something much more common like the Model M.
Offline y11971alex
« Reply #38 on: Thu, 07 July 2016, 17:42:25 »
They're not terribly unreliable, I think, having survived (for some) 40 years of use, disuse, or abuse to surface again this day and age.
Offline chyros
  • a.k.a. Thomas
« Reply #39 on: Thu, 07 July 2016, 18:03:45 »
The mechanism is not as robust as the F buckling springs that came later. Beam springs are more sensitive to contamination, and there's this weird membrane and stuff covering everything which inevitably decomposes over time. The boards themselves also can be quite rusty, from what I hear.
Offline SBJ
  • Tactile pls
« Reply #40 on: Thu, 07 July 2016, 21:28:44 »
wow - nice, thanks!
I'd love to hear that top 5 please :D
I'm currently on Gateron Greens and they're great, but I was wishing for a little more tactility (sp?)
Offline mike52787
  • Alps Aficionado
« Reply #41 on: Thu, 07 July 2016, 22:29:07 »
wow - nice, thanks!
1: Alps SKCM Blue
2: Capacitive BS (model F)
3: Click Modded Alps SKCl green
4: Membrane BS (model M)
5: Alps SKCM White
This is just a personal list, others can comment on this, but theres quite a few switches I havent tried, and I have only tried a loose skcm blue from a switch tester. I do have 2 SKCM blue boards in the mail tho :D
Offline chyros
  • a.k.a. Thomas
« Reply #42 on: Fri, 08 July 2016, 05:00:56 »
wow - nice, thanks!
1: Alps SKCM Blue
5: Alps SKCM White
I agree pretty closely, I tend to put F's and SKCM blue on the same level as well as M's and SKCM white. My top clicky switch list is probably something like:
1) CBS / SKCM blue
2) MBS / SKCM white
3) Aruz / SMK 2nd gen
Offline SBJ
  • Tactile pls
« Reply #43 on: Fri, 08 July 2016, 05:18:36 »
wow - nice, thanks!
1: Alps SKCM Blue
5: Alps SKCM White
1) CBS / SKCM blue
2) MBS / SKCM white
Where would I go about searching for a board with blues? I am very intrigued.
Thank you.
« Reply #44 on: Fri, 08 July 2016, 05:43:32 »
I got mine from eBay, something like these:
http://www.ebay.com.au/itm/191782632415
Offline chyros
  • a.k.a. Thomas
« Reply #45 on: Fri, 08 July 2016, 06:50:18 »
wow - nice, thanks!
1: Alps SKCM Blue
5: Alps SKCM White
1) CBS / SKCM blue
2) MBS / SKCM white
Thank you.
They pop up on eBay somewhat regularly. They're not rare, but they have a fierce reputation, and this has driven up their price considerably. When in great condition, they're outstanding switches though, and they have the best typing sound of any switch I've tried so far.
Whatever you do, I can't stress this enough — DON'T SETTLE FOR A DIRTY ONE. Make sure it's as squeaky clean as possible. Even small amounts of dirt will make the keyfeel considerably worse.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #46 on: Sun, 10 July 2016, 15:10:41 »
It's ok to admit you completely forgot about beam springs.
I don't get the love for (blue) alps, they're nowhere near as smooth as the IBM BS.
And Beam Springs are in a league of their own.
