Author Topic: Whats your guys favourite Zealios switch weight?  (Read 5163 times)
Offline snarfarlarkus
« on: Thu, 07 July 2016, 02:43:28 »
About to buy a zealios board but just wanting some insight as to which switch weight would be best for me. I'm going for the tactile ones. Thanks
Offline gaunt
Re: Whats your guys favourite Zealios switch weight?
« Reply #1 on: Thu, 07 July 2016, 06:05:18 »
I'd go for the 78g versions unless you really like light switches (e.g. cherry reds).
« Reply #2 on: Thu, 07 July 2016, 06:10:50 »
That's entirely objective.
No-one except you can decide which switch you like best.
« Reply #3 on: Thu, 07 July 2016, 06:23:19 »
I usually like stiff swithces but had the pleasure of using a board of 65g Zealios and they were surprisingly nice.
As rowdy says no-one can answer what's best for you though, you need to try for yourself.
Offline Data
« Reply #4 on: Thu, 07 July 2016, 06:41:43 »
65g is the sweet spot.
LIKE BUTTAH!
Offline spiritanimals
« Reply #5 on: Thu, 07 July 2016, 07:19:22 »
Ig you are completely unsure, get 65g. Not sure of that is what is best for you, but that's the in-between. If you're really curious, buy a few switches, pop them in a tester and figure out what you like best. Personally, I'd love to get lubed 67g switches. I'm sure you can find some reviews on the board.
« Reply #6 on: Thu, 07 July 2016, 20:01:12 »
Thanks for the replies guys. Yeah I know I need to try for myself but I cant... Can just afford one board. I've been using a Model F AT for the past year now yet I don't know they're actuation force weight however, I know they're heavier than reds or blues but lighter than my Model M. I did like reds and blues but I don't know reds seemed a bit too light for me. I'm kinda stuck between 67g or 78g. Just want something more crisp and tactile? Need more insight on how the keystroke feels?
Offline clacktalk
  • circa 2015
« Reply #7 on: Thu, 07 July 2016, 20:39:25 »
i like the purple ones because i type capless so i can rly enjoy the stem color at all times
diary of a clacktalk
radio_killah: too much frank
Offline Aricil
« Reply #8 on: Fri, 08 July 2016, 14:33:49 »
Now, I've never tried zealios switches, so take this with a grain of salt. But I've got a friend on steam who tried the different switch weightings and he said that he vastly preferred the 67 g spring compared to all the others. =/ Just throwing that out there.
Professional amateur.
Offline klennkellon
  • I like bottoming out
« Reply #9 on: Fri, 08 July 2016, 14:42:02 »
I like all of my switches around 60g to 67g, any lighter and I make a lost of mistakes but any heavier and I find it feels like more of a chore to type on.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #10 on: Fri, 08 July 2016, 15:16:30 »
Have you tried any other tactile switches that you like? Some say that 65g Zealios are like Ergo clears, but I don't think they are....
Offline piemancoder
« Reply #11 on: Sat, 09 July 2016, 09:58:37 »
Wouldn't that be subjective?
Yoda grammar best has
