Author Topic: Problem: GH60 Satan boards and Zealios  (Read 4246 times)
Offline tofgerl
« on: Fri, 08 July 2016, 09:46:07 »
Problem: Got some new GH60 Satan boards in to put Zealios on. tested the first board with no keys, and it registered fine. "Typed" a few letters with a pair of tweezers. Bingo.
Put the zealios in the correct places, soldered them on.
Tested again, and suddenly the board doesn't register at all. No USB device, no signal.
My other keyboards work, I've changed cables...
What's the next thing to try?
Mod Edit: This was split from the Simple Questions, Simple Answers thread.
« Last Edit: Sat, 09 July 2016, 09:42:42 by infiniti »
Offline tofgerl
Re: Re: Simple Questions, Simple Answers (FAQ in the OP)
« Reply #1 on: Sat, 09 July 2016, 05:46:52 »
Apparently this keyboard only works on weekends. Works fine now. Tried everything yesterday, today it's sitting there like a good dog and doing everything I wanted it to.
Do keyboard controllers have moods...?
Edit: Aaaaand re-dead. Zombieboard!
« Last Edit: Sat, 09 July 2016, 05:55:14 by tofgerl »
Offline stoic-lemon
« Reply #2 on: Sat, 09 July 2016, 07:22:33 »
I am far from an expert, but that suggests a dodgy connection somewhere. Perhaps the USB header? Is it a case at the moment?
Also this isn't a simple question now  ;)
Offline tofgerl
« Reply #3 on: Sat, 09 July 2016, 07:31:20 »
It is put in a case, as I don't like leaving it just on the desk surface, but it is not fastened to the case, and I've tried connecting it without the case as well. It's an alu case. I might try a plastic case, but I can't see how that would help.
I do agree with the dodgy connections, but I have no idea how to check. I have a multimeter, but I've only ever used it to check if a is connected to b. I have no idea which parts of the board should be connected to what...
I'm gonna take some pictures of the connectors and put them on imgur.
Offline tofgerl
« Reply #4 on: Sat, 09 July 2016, 07:40:20 »
http://imgur.com/a/RP8Zd
In the top picture you will see another keyboard that I put together the exact same way with the same switches just a couple of hours later, proving that I can actually make one.
I don't really know what to focus on, so ask for more angles if anyone needs it, or wants me to struggle with an old camera.
Oh, and I'm still uploading. I'm on a bad connection until the ISP upgrades whatever they need to upgrade.
Offline odd
Re: Problem: GH60 Satan boards and Zealios
« Reply #5 on: Sat, 09 July 2016, 15:01:41 »
I'm on my 2nd PCB that has had the 7th col just die on me. I think thees are just extremely cheap boards
Offline stoic-lemon
« Reply #6 on: Sat, 09 July 2016, 21:29:21 »
That's really odd. guess you would put one probe of the multimeter one one of the USB pads, and the other on the corresponding pad on the connector itself. I was going to suggest it might be a driver issue, but since the board works sporadically, that can't be the problem I suppose.
Offline tofgerl
« Reply #7 on: Sun, 10 July 2016, 10:40:43 »
This is the first board I have had problems with. I've got six Satan boards total, of which this was the fourth. I'm typing on the fifth, and the sixth is still in the plastic wrapping.
Of course it could be a connection issue, but I have no idea if it's even fixable, and I'm 99% sure it's not fixable BY me.
I think it might have happened during the installation of the switches, since I use PCB mounted switches and the board bends really easily. Right now I'm just thinking "desolder the expensive Zealio switches and put them on the last board". It's not like the board was super expensive, and since I have other keyboards laying around, I don't really feel like I need to fix it either.
Offline KHAANNN
« Reply #8 on: Wed, 13 July 2016, 06:45:24 »
I was once testing a custom PS/2 - USB converter I built, I tested it with an 60% PCB that wasn't compatible with the PS/2 wiring, also my custom converter was incorrect too, so I jolted both the laptop I was testing with, and the PCB
Laptop recovered fast, the PCB stopped working, I tested it with multiple systems, it wasn't working
But after a while, the PCB started working again
So my point is, you might have jolted something, whether it's a static jolt or an unintentional short circuit or something, and you might have been lucky enough that it recovered
Grounding is a common practice for pc builders, yet for keyboard building, I don't think it's too common, but same risks still apply
Offline tofgerl
« Reply #9 on: Wed, 13 July 2016, 06:46:42 »
Perfectly possible... I wonder how I unjolt it. Time?
Offline KHAANNN
« Reply #10 on: Wed, 13 July 2016, 07:19:19 »
Time + Luck I guess, not all keyboard pcbs turn back from the death
It's why I fancy the Phantom PCB, worst case scenario, you would replace the Teensy with a new one
Offline tofgerl
« Reply #11 on: Wed, 13 July 2016, 08:23:59 »
Yeah, desoldering these 61 zealios is not on my bucketlist...
Offline Moistgun
  • Slippery When Wet
« Reply #12 on: Wed, 13 July 2016, 09:14:40 »
Given that the pcb is soooo clean, is there any chance you went at it with 99% alcohol and a toothbrush?
If you did, you could have knocked something loose at the controller.
Offline tofgerl
« Reply #13 on: Wed, 13 July 2016, 09:19:52 »
Nope, it's just legitimately clean. All I've done is soldered 61 switches to it.
Still no connection by the way. Just that one time on monday.
Offline Moistgun
  • Slippery When Wet
« Reply #14 on: Wed, 13 July 2016, 16:10:27 »
And youve tested it on another computer I assume?
Sorry if I missed this above  :rolleyes:
Its not that uncommon to have Satan's failing.  the threads are a mix of ineptitude with programming, but the other half are legitimate DOAs
Offline tofgerl
« Reply #15 on: Thu, 14 July 2016, 04:48:52 »
Sure, different computers and operating systems.
Now I've desoldered all the switches, I'll just throw it away. Still no connections.
Offline KHAANNN
« Reply #16 on: Thu, 14 July 2016, 05:02:15 »
Good riddance
That USB connector type is cancer anyway, it would break with the smallest force and ruin your day in the future
Offline tofgerl
« Reply #17 on: Thu, 14 July 2016, 06:47:22 »
And here I am switching keyboard several times a day with the same cable... Hmm..
Offline Data
« Reply #18 on: Thu, 14 July 2016, 07:34:56 »
The problems with Mini-USB are highly anecdotal.  I understand the PC industry in general has moved away from it, but if it was truly awful all these keyboard companies would have abandoned it a long time ago.  You think Leopold, Ducky, WASD, etc who care about making a quality product would ignore something as critical as the connector port?  What about all the Korean customs that we worship?
Not saying there aren't better ports we could be using but the Mini-USB does the job just fine, thank you.
Offline KHAANNN
« Reply #19 on: Thu, 14 July 2016, 08:17:41 »
It's not the mini-usb, but the surface mount connector he shared here: http://imgur.com/a/RP8Zd
Thanks for the speech tho :)
I personally love mini-usb too, wouldn't want to get a new set of custom cables
