Author Topic: Ye olde Model M  (Read 4267 times)
Offline QuincyJones
Ye olde Model M
« on: Wed, 13 July 2016, 16:18:23 »
So, it's come and it's a 1986-1988 apparently. Nice and... "creamy". I'm pretty sure I can get some fingerprints off this thing! Maybe from the printers floor or mechanics shop.
« Last Edit: Wed, 13 July 2016, 16:20:37 by QuincyJones »
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline emdude
Re: Ye olde Model M
« Reply #1 on: Wed, 13 July 2016, 16:24:04 »
Looks unusually yellow for a Model M, wonder why that is.
Current drivers: IBM Model M SSK
Offline QuincyJones
Re: Ye olde Model M
« Reply #2 on: Wed, 13 July 2016, 16:35:50 »
Yeah, the base is mostly beige, there's a gradient yellowing-to-beige around the back though.
(please like me)
Offline y11971alex
  • Looking for Toronto meetup
Re: Ye olde Model M
« Reply #3 on: Wed, 13 July 2016, 16:41:43 »
Cigar smoke :D
Offline E TwentyNine
    • Some of My Keyboards
Re: Ye olde Model M
« Reply #4 on: Wed, 13 July 2016, 16:47:31 »
Bet it's a Greenock board.  They had some different materials sometimes for the spacebar, maybe they had some variation on the case material as well.
Offline QuincyJones
Re: Ye olde Model M
« Reply #5 on: Wed, 13 July 2016, 16:49:01 »
Yep - it is! They also made the worst labels with the shortest lifespan by the looks.
Incidentally, judging by the amount of dirt that's on the keys, you can see that the original owner didn't like using commas nor semi-colons and also that Dvorak was right! Look at all those unused keys on the home row!
« Last Edit: Wed, 13 July 2016, 16:51:53 by QuincyJones »
(please like me)
Re: Ye olde Model M
« Reply #6 on: Wed, 13 July 2016, 16:58:10 »
Dirt-wise I would call that about average for a salvaged Model M. Should clean up nicely with soap and water and maybe some aggressive scrubbing in places.
I hate it when those legends get shifted so far to the left.
- D Trump 2026-10-24
Offline QuincyJones
Re: Ye olde Model M
« Reply #7 on: Wed, 13 July 2016, 17:03:32 »
Yeah, I'm tempted to clean the caps now, but don't want to put them back on a dirty keyboard to only have to pull them off again, so am forcing myself to wait until I can get something to open it with! Went around 4 DIY stores today to not find a single driver suitable!
(please like me)
Re: Ye olde Model M
« Reply #8 on: Wed, 13 July 2016, 17:13:31 »
Try an auto store. The socket needs to be "long" and "thin-walled" that is, intended to snake down into narrow spaces as are often found around engines.
Offline QuincyJones
Re: Ye olde Model M
« Reply #9 on: Wed, 13 July 2016, 17:27:31 »
Heh, I did! The assistant was like "what's a nut driver?" They had a set of about 8 drivers, but not 5.5mm / 7/32's
(please like me)
Offline QuincyJones
Re: Ye olde Model M
« Reply #11 on: Wed, 13 July 2016, 20:20:31 »
You might find a socket much easier than a nut driver.
http://www.ebay.com/itm/XCELITE-7-32-Hollow-Shaft-HS7-Nut-Driver-Free-Shipping-/291808572296?hash=item43f1257388:g:RxgAAOSwMHdXS54g
http://www.ebay.com/itm/Craftsman-9-32-1-4-7-32-3-16-1-6mm-6-Point-Deep-Laser-Etch-Socket-1-4-Drive-/361635448002?hash=item54332704c2:g:fE4AAOSwvg9Xe1b7&item=361635448002&vxp=mtr
You know, I did actually look in the car shop, but they only had locked-away sets. But yeah, just checked on ebay, and trying to find something with the clearance will be tough, but it's a great lead - thanks.
btw - what is the distance from case hole to screw? 1/2"?
(please like me)
Offline klennkellon
  • I like bottoming out
Re: Ye olde Model M
« Reply #12 on: Wed, 13 July 2016, 20:26:19 »
Cigar smoke :D
That's what I'm thinking, but then wouldn't the keycaps be yellowed too?
Model M's case isn't PBT as far as I know though, so maybe cigar smoke yellows it anyway.
I know the Greenock made ones had ABS spacebars with that weird grounding thing but I don't think they did it with the whole board.
Re: Ye olde Model M
« Reply #13 on: Wed, 13 July 2016, 20:27:24 »
Easily. 2 full cm
Offline emdude
Re: Ye olde Model M
« Reply #14 on: Wed, 13 July 2016, 20:32:19 »
Cigar smoke :D
PBT as far as I know were only used in key caps due to their brittleness.  I believe Model M cases use some PVC mix.
« Last Edit: Wed, 13 July 2016, 20:34:49 by emdude »
Offline y11971alex
Re: Ye olde Model M
« Reply #15 on: Wed, 13 July 2016, 20:33:39 »
Cigar smoke :D
I am inclined to think that the Model F seems to yellow more easily than the Model M, and this could be due to the painted surface.
Offline QuincyJones
Re: Ye olde Model M
« Reply #16 on: Wed, 13 July 2016, 20:34:57 »
Cigar smoke :D
You know, if it was smoke, wouldn't it be uneven? And surely there'd be a HELL of a lot of smoke to yellow the top evenly and fade away - was it inside a 3ft cube room? Also, the parts not typically exposed to sunlight - the bottom and the rear lower-half of the bottom case is beige with a strage gradient on the back.
I'd expect to see burn marks on it too - I did pick up a keyboard from a smoker once and there were remnants of ash marks and browny/orange lines from where they'd placed the cigarette on it. Cleans up fairly nicely though.
Also 2.3KG heavy - is that typical?
« Last Edit: Wed, 13 July 2016, 20:41:59 by QuincyJones »
(please like me)
Re: Ye olde Model M
« Reply #17 on: Wed, 13 July 2016, 20:50:51 »
Yes, and the old ones were half a kg more than that.
Offline y11971alex
Re: Ye olde Model M
« Reply #18 on: Wed, 13 July 2016, 21:31:41 »
That would make it 2.8 kg, which is 200g more than a Model F XT.
Offline ThoughtArtist
Re: Ye olde Model M
« Reply #19 on: Wed, 13 July 2016, 22:52:14 »
Thank the lord that plastic mixture didn't make it out of that one factory!
