Author Topic: Damaged Model F XT connector - advice?  (Read 4700 times)
Offline BSJunky
« on: Wed, 13 July 2016, 23:07:34 »
I damaged my Model F's connector when disconnecting it from the orihalcon soarer's converter... as you can see, the XT connector wound up with a sort of involuntary sex change. How can I fix this? (It no longer responds at all, no matter how hard I press everything together...)
http://imgur.com/h2dQVy0
« Last Edit: Wed, 13 July 2016, 23:41:31 by BSJunky »
Offline Tactile
Re: Damaged Model F XT connector - advice?
« Reply #1 on: Wed, 13 July 2016, 23:40:29 »
You can replace it with a "5 pin DIN connector". They're quite commonly available. You'll just need to dissect it to get the wire colors/positions & match the new connections.
« Last Edit: Fri, 15 July 2016, 21:42:32 by Tactile »
REΛLFORCE
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Fri, 15 July 2016, 11:36:15 »
I would send you mine, but Im keeping it around because I have an original 5150 and 5151. I did an internal teensy mod on mine, so I just detatched the cable. I would actually suggest doing that, so no damage comes to the cable. It is a very simple mod and It can be done in ~20 minutes if youre decent at soldering.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Fri, 15 July 2016, 11:44:17 »
i just threw one out... i'll check the office can when i get home on monday and if i still have it i'll mail it to you if you want. I went the other direction and put a usb mini-b port in the hole where the cable came out of the board.
-Dana
Offline QuincyJones
« Reply #4 on: Fri, 15 July 2016, 16:46:10 »
how are you attaching the board to the case? some sort of adhesive tape?
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline mike52787
  • Alps Aficionado
« Reply #5 on: Fri, 15 July 2016, 17:23:41 »
I just used a small amount of hot glue. Its easily removed with acetone so no big deal when I need to remove the teensy.
Offline BSJunky
« Reply #6 on: Fri, 15 July 2016, 23:25:53 »
Thanks very much for the replies.
Unfortunately, I have zero experience with soldering or any type of electronics work. Is this repair feasible for a total novice? If so, where would I begin...? (If not, can I pay one of you guys to do it??)
« Last Edit: Fri, 15 July 2016, 23:39:23 by BSJunky »
Offline mike52787
  • Alps Aficionado
« Reply #7 on: Sat, 16 July 2016, 07:44:14 »
I could teensy your f for you, all you would have to pay would be shipping there and back and the teensy. PM me if youre interested.
Offline BSJunky
« Reply #8 on: Tue, 19 July 2016, 21:13:45 »
Perhaps I should have mentioned that I *am* willing to learn. Could someone perhaps give me a very basic rundown of what this repair would involve? Maybe a link to or two?
mike52787: Thank you very much for the generous offer. I may take you up, but I would have to insist on paying you something for your time.
Offline Tactile
« Reply #9 on: Tue, 19 July 2016, 23:22:52 »
Here's a quick rundown on it. It's not difficult if you have soldering gear.
REΛLFORCE
