Author Topic: How to mitigate backlight bleed-through on underside of keycaps?  (Read 8481 times)
Offline Art of Payce
I like Varmilo's mint front-side printed PBTs, but I don't like the blacklight bleed. See video for reference. I'm thinking about painting the undersides with really fine paint marker. Any ideas?
Offline Raenbo
  • IG: @aero_keys
Re: How to mitigate backlight bleed-through on underside of keycaps?
« Reply #1 on: Sat, 16 July 2016, 05:11:24 »
I've put small pieces of black electrical tape on the underside of the keycap where the LED is located. It still lets the light disperse around the cap, but stops that big blob of light that hits the cap.
« Reply #2 on: Sat, 16 July 2016, 05:49:21 »
This seems quite effective.
« Reply #3 on: Sat, 16 July 2016, 08:01:40 »
Not a bad idea for a diffused effect. However...
This is it. I didn't realize such tape existed. Thank you.
Also, your quote is a most elegant justification and conversation piece for my coworkers in the future.
« Reply #4 on: Sun, 17 July 2016, 02:39:47 »
A quote from the great (or humble, as he would probably have it) Eiiti Wada himself!
You can read the full interview here: https://www.keychatter.com/2016/01/04/interview-professor-eiiti-wada-creator-of-the-hhkb/
Offline zephyr11
« Reply #5 on: Mon, 18 July 2016, 22:26:45 »
this is such a good idea! I was wondering if someone found them slightly annoying like I do. I do like them led lights, but it does looks a bit odd when I see the underside of the kecaps more clearly then the lettering on the keycap.  :mad:
Offline Phenix
« Reply #6 on: Tue, 19 July 2016, 15:18:47 »
So to sum up:
I just stick aluminium tape into the inside of the caps?
And where can I get that tape!?
Winter is coming.
« Reply #7 on: Tue, 19 July 2016, 21:44:49 »
So to sum up:
The thread I linked suggests the tape is used for ducts and such - so maybe an air-conditioning supply business?
Offline TwitchXL
« Reply #8 on: Sat, 23 July 2016, 14:45:14 »
I did the same on a friends boarde Used electrical tape and its perfect
Filco MJ2
