Author Topic: Model M for Maybe  (Read 2389 times)
Offline Vortex324
Model M for Maybe
« on: Thu, 21 July 2016, 15:52:04 »
I was told that I can have the Model M keyboard if I can replace it with another keyboard that will work with a IBM Display Terminal (PN: 66G1725). I tried just plugging in a PS2 keyboard but that didn't work. The keyboard looks like it's plugged into an RJ45 jack. Someone help!
Sent from my Nexus 6P using Tapatalk
Offline E TwentyNine
    • Some of My Keyboards
Re: Model M for Maybe
« Reply #1 on: Thu, 21 July 2016, 16:38:21 »
You normally can't hotswap a PS/2 keyboard.   If you didn't try it with the terminal off and the keyboard plugged in before turning it on, try that.
Don't think those supported mice, but if they did could be a port for that or something else entirely...
Offline y11971alex
  • Looking for Toronto meetup
« Reply #2 on: Thu, 21 July 2016, 18:13:40 »
I'm under the impression that you need the specific model of keyboard shipped with the terminal for it to work properly, if your terminal predates Set 3 protocol. IBM made a large variety of terminals and different keyboards to go with them.  So if you were to acquire that Model M, you might just need to replace it with another identical Model M.
« Reply #3 on: Thu, 21 July 2016, 18:59:07 »
Precisely why Orihalcon, standing on the shoulders of Soarer, has given the world such an extraordinary set of tools.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline y11971alex
« Reply #4 on: Thu, 21 July 2016, 19:57:02 »
If this is a terminal Model M, I scarcely think it would be worth the expense to purchase one from Orihalcon.
« Reply #5 on: Thu, 21 July 2016, 20:21:55 »
Whatever. For slightly less than the price of an Orihalcon, you can build:
https://geekhack.org/index.php?topic=58941.msg1348717#msg1348717
- Plato
« Reply #6 on: Thu, 21 July 2016, 20:29:51 »
Note that it has got a PS/2 port on it, so it postdates set 3.  Even if that port isn't used for a keyboard.
Even if predates it, there's only a few variations of the terminal boards (two? three?), and there were/are aftermarket versions.
But if the ps/2 port is enabled for keyboard use all that's moot.  If it's not I'd be curious why it's there.
Offline y11971alex
« Reply #7 on: Thu, 21 July 2016, 21:33:31 »
Are we sure that is the PS/2 port?  Aren't there other applications of the 6-pin Mini-DIN plug elsewhere?  :D
Offline Vortex324
« Reply #8 on: Fri, 22 July 2016, 01:24:48 »
So I'm hearing that I'll have to wait till the equipment gets retired and should just buy one.
