Author Topic: Flat Keyboards  (Read 5796 times)
Offline exia
Flat Keyboards
« on: Mon, 04 January 2010, 16:05:01 »
It seems that many mechanical keyboards have the keyboard angled up (a bit more than other non-mech keyboards). What is the reason? Are the keyboards supposed to be used with a wrist rest, is that the reason for the extra height?
If I buy a mechanical keyboard it will be angled higher and there would be no way to get the keys down closer to the desk. I prefer the keyboard to be as flat on the desk surface as possible. That is how logitech says it. It gives the most comfort because the wrist is not bent. It is the natural way to type.
Why do the mechanical keyboard companies make it harder on the users? First they price they way higher than what they are really worth and now this.
« Last Edit: Mon, 04 January 2010, 18:34:14 by exia »
Offline itlnstln
Flats Keyboards
« Reply #1 on: Mon, 04 January 2010, 16:27:44 »
I don't have a problem, per se, with the angle of the keyboard.  I use a wrist rest, though.  The main thing with mechanical keyboards, though, is that they need room for the internals, so they will never be as thin as rubber domes.
Offline timw4mail
    • https://timshomepage.net
Flats Keyboards
« Reply #2 on: Mon, 04 January 2010, 16:28:11 »
Well, most keyboards have feet to make the angle steeper. Totally flat keyboards probably aren't very ergonomic either.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
Flats Keyboards
« Reply #3 on: Mon, 04 January 2010, 16:32:00 »
Quote from: timw4mail;147946
This.  The MS Natural 4000 has an optional riser to lift the front of the keyboard, so your wrists are bent the other way.  This was much less comfortable, IMO.  That said, I do like my 'boards as flat as possible.  I use mine with the back feet in.
Offline ch_123
Flats Keyboards
« Reply #4 on: Mon, 04 January 2010, 16:37:28 »
Quote from: exia;147939
And you type on a full travel board without bending your wrists quite easily.
Did you know that research funded by tobacco companies says that smoking can't kill you? And that research funded by the Catholic church 'found' that the HIV virus can get through the pores in the latex on condoms? *
[size=-4]*The particular hilarity about that one is that a HIV virus is several orders of magnitude larger than a single sperm, but I digress.[/size]
« Last Edit: Mon, 04 January 2010, 16:40:15 by ch_123 »
Offline Buckling_Summer
    • http://www.elitesportservices.com
Flats Keyboards
« Reply #5 on: Mon, 04 January 2010, 16:50:09 »
Quote from: ch_123;147951
Hilarious! Companies funding research ! How unbiased !
PRESENT POSSESSIONS:
 Buckling Spings: IBM Model M 82G2383 Lexmarkian (1995) / IBM Model F PC-AT keyboard 84 keys (6450200)
XM Simplified 1 (Monterey K110 or AK-CN2 or Hua-Jie) Siig MiniTouch KB-1948 GeekHack Spacesaver edition
Offline nanu
    • http://T-T.be/portal
Flats Keyboards
« Reply #6 on: Mon, 04 January 2010, 17:43:33 »
What itlnstln said.  Mechanical switches are potentially bulky.
But you're right, if you're bothered by the increase in height relative to the keyboard's surface like I was, you may have to do something about it, too.
I went from this
<404 image>
to this
but I'm currently doing it like so
« Last Edit: Wed, 17 March 2010, 14:32:16 by nanu »
Offline nanu
Flats Keyboards
« Reply #7 on: Mon, 04 January 2010, 17:56:40 »
yep
Quote from: ripster;147977
Bwahahahaha!
You guys realize Exia will never buy a keyboard?
But it is fun to watch.
Quote from: ripster;147978
Exia, get a Deck Legend.
Offline AndrewZorn
Flats Keyboards
« Reply #8 on: Mon, 04 January 2010, 18:20:26 »
flats keyboards
Offline InSanCen
Flats Keyboards
« Reply #9 on: Mon, 04 January 2010, 18:34:34 »
Quote from: ripster;147984
So far Exia has posted he's getting a IBM mini, a Realforce, a scissor switch, a Razer, a Logitech Access 600,  a wireless and a left handed keyboard.
I figure he needs more to chew on.
P.S.  And he despises your wooden one.
I'm still partly convinced he's an epically sycessful troll.
@exia
Just buy a board already. Pretty much any switch will likely show up any non-Topre based rubber dome. If you like light get something with blue cherries. TVS gold's are cheap enough. Until then, just STFU. Welcome to MsWindows land, on my ignore list.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Mercen_505
Flats Keyboards
« Reply #10 on: Mon, 04 January 2010, 18:44:26 »
The funny thing is that, for the most part, we're a troll-proof forum, as we have a wide and generally accepted pool of knowledge, and we understand that although there are a few subjects up for debate (switch type, for example) we've already debated them to death.
In answering the OP's question, webwit totally nailed it.
« Last Edit: Mon, 04 January 2010, 18:45:24 by Mercen_505 »
Offline ch_123
Flats Keyboards
« Reply #11 on: Mon, 04 January 2010, 19:05:33 »
Also, our complete inability to stay on topic tends to work against trolling.
Offline timw4mail
Flats Keyboards
« Reply #12 on: Mon, 04 January 2010, 19:19:00 »
Quote from: ch_123;147998
Wait, that isn't a normal forum thing?
Offline bigpook
Flats Keyboards
« Reply #13 on: Mon, 04 January 2010, 19:21:10 »
Quote from: timw4mail;148003
certainly not here.
Offline ch_123
Flats Keyboards
« Reply #14 on: Mon, 04 January 2010, 19:23:04 »
Not really. On other forums which I post on, staying on topic is quite strictly enforced by the mods. In fact, if this was some of the other forums I can think of, we'd all have been banned a long time ago.
Offline bigpook
Flats Keyboards
« Reply #15 on: Mon, 04 January 2010, 19:24:31 »
Quote from: ch_123;148005
wow, that would pretty much kill this site.
Offline ch_123
Flats Keyboards
« Reply #16 on: Mon, 04 January 2010, 19:28:31 »
Depends on what you're catering for. Said forums I've described are for games and the like, where you get a lot of argumentative kids and clueless dip****s. Geekhack is reasonably self-policing in that it is of interest only to a relatively small number of... odd people.
Offline exia
Flats Keyboards
« Reply #17 on: Mon, 04 January 2010, 19:34:09 »
On the topic screen the title says "Flats Keyboards", how do I edit the title?
Offline bigpook
Flats Keyboards
« Reply #18 on: Mon, 04 January 2010, 19:37:47 »
Quote from: ch_123;148010
who you calling odd?
I'm just different...
« Last Edit: Mon, 04 January 2010, 19:44:40 by bigpook »
Offline itlnstln
Flats Keyboards
« Reply #19 on: Tue, 05 January 2010, 08:37:32 »
Quote from: webwit;147949
You do like your broads as flat as possible? Oh wait.
Well, it's better than saggy.
Offline overdriver
Flats Keyboards
« Reply #20 on: Tue, 05 January 2010, 11:22:00 »
Quote from: bigpook;148014
odd, different is the sign of elite geek :rockon:
OmniKey 101 - the perfect keyboard
Chicony KB-5181 - SMK Monterey Blue switch
Cherry G86-6241OEUAGSA - Cherry Brown switch
IBM M 1378160(Ambra)
Dell AT101w / AEK II
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Flats Keyboards
« Reply #21 on: Tue, 05 January 2010, 11:47:27 »
Going off-topic seems to be a typical geek thing - it also is quite common on Usenet. There it's much easier to change the subject on a discussion branch though - "new subject (was: old subject)", then "new subject" on replies. I think some newsreaders like 40tude Dialog even do that automagically, though I haven't used the function is a long time...
Odd people... yeah, maybe. ;) Not the most boring ones though...
Quote from: exia;148011
Isn't that one of those things that don't work here (but hopefully will at some time)...?
Offline o2dazone
Flats Keyboards
« Reply #22 on: Wed, 06 January 2010, 00:23:22 »
There's enough terrible forums on the internet where power hungry "SRS BIZNESS" moderators ban users and lock up posts for not staying on topic. I find this forum more interesting to read, and I still get all the technical information I need ( I might not just find it in a specific post, but thats what search is for).
Offline spolia optima
Flats Keyboards
« Reply #23 on: Wed, 06 January 2010, 01:20:23 »
i likes my keyboards like i likes my women: flat and squishy, with rubber domes and big, fat asses.
keyboards!
Offline hyperlinked
Flats Keyboards
« Reply #24 on: Wed, 06 January 2010, 01:52:20 »
Quote from: spolia optima;148353
It's a shame that your keyboards don't get a chance to refuse their choice of user.
KIDDING! KIDDING!
« Last Edit: Wed, 06 January 2010, 02:00:46 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline ricercar
  • mostly abides
Flats Keyboards
« Reply #25 on: Wed, 06 January 2010, 02:09:41 »
I rather enjoy the tangents.
The OP writer can change the thread title using Go Advanced (assuming enough time hasn't passed to prevent editing of the OP.
Flats Keyboards
« Reply #26 on: Wed, 06 January 2010, 02:42:56 »
No, it's true. If my keyboards had the choice, they wouldn't want me anywhere near them. Luckily, they don't have that option. And this is why keyboards are better than human relationships.
keyboards!
