Author Topic: Keyboards with lowest actuation force?  (Read 15300 times)
Offline tiger
« on: Fri, 22 July 2016, 14:12:48 »
What's available for low actuation force TKL keyboards?
Topre's are silly heavy.
The Cherry MX switches are too stiff as well.
Any options in the sub 20g actuation range?
I learned how to touch type on the TouchStream LP. It was hands down the best input device I've ever used. Miss it dearly. Looking for something modern that can be on par.
Offline klennkellon
  • I like bottoming out
Re: Keyboards with lowest actuation force?
« Reply #1 on: Fri, 22 July 2016, 14:38:43 »
There was a mod for a rubber dome awhile back that reduced the force to something like 10g.
https://geekhack.org/index.php?topic=81368.0
The lightest actual key switch you could get would be 35g Topre
Offline Waateva
« Reply #2 on: Fri, 22 July 2016, 14:42:46 »
If you could get a board with Gateron Clears they are also 35g, but between that and Topre 35g I don't know of anything that comes lighter stock.  Maybe you could find some really light springs to mod, but I can't find anything online lighter than 35g.
« Last Edit: Fri, 22 July 2016, 14:58:53 by Waateva »
« Reply #3 on: Fri, 22 July 2016, 14:48:56 »
As I noted in the thread you linked, you can remove the helical spring from Cherry MY switches and depend on the leaf springs alone for something like 15g.
I have not performed the mod myself but I have used a keyboard which had been modded in that way and it was very light.
- Plato
« Reply #4 on: Fri, 22 July 2016, 14:53:36 »
If you could get a board with Gateron yellows they are also 35g, but between that and Topre 35g I don't know of anything that comes lighter stock.  Maybe you could find some really light springs to mod, but I can't find anything online lighter than 35g.
I think you meant gateron clear as gateron yellow are between red and black which is heavier than 35g.
Offline Waateva
« Reply #5 on: Fri, 22 July 2016, 14:59:25 »
Shoot you're right, I fixed it now! :D
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Fri, 22 July 2016, 16:30:33 »
I have performed the Cherry MY spring-removal mod. The result is around 25 cN, and it's impossible to even touch keys without actuating them.
At this point, however, it's worth in looking into non-mechanical input devices, and I absolutely don't mean rubber domes, but rather stuff like the TouchStream, LigthIO, or, say, Dasher combined with a trackpad.
Offline 1swt2gs
  • DOGE
« Reply #7 on: Fri, 22 July 2016, 16:53:18 »
You all have some light ass hands.
I set off mx reds by just lining up my fingers on home row
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline y11971alex
  • Looking for Toronto meetup
« Reply #8 on: Fri, 22 July 2016, 18:24:22 »
LIM (Activation force) → 0.
« Last Edit: Fri, 22 July 2016, 18:25:53 by y11971alex »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #9 on: Fri, 22 July 2016, 19:41:19 »
You can activate it with no force at all, capsense can generally detect fingers before they even touch a screen :p .
The lowest-force stock unmodded switches I own are Fujitsu magnetic reed at 35 cn. I think the Matias linears have the same force.
Offline tiger
« Reply #10 on: Fri, 22 July 2016, 21:13:08 »
Thank you all for the great ideas.
Offline SBJ
  • Tactile pls
« Reply #11 on: Sat, 23 July 2016, 06:12:01 »
I'm using Greens at the moment and they are light for me. I'm wondering if there is anything out there that would satisfy my 'heavy hands' - I kinda have my eye out after a Realforce 87U 55g.
« Reply #12 on: Sat, 23 July 2016, 08:16:22 »
I remember trying one of Haata's modded boards, I believe it was MX. light as ****, and I've got a pretty soft touch normally.
Offline chyros
  • a.k.a. Thomas
« Reply #13 on: Sat, 23 July 2016, 10:52:44 »
I think someone made an enormous board out of 10 cn microswitches btw. There was a film of it on YT IIRC.
Offline Fictiouz
  • That "White" Guy
« Reply #14 on: Sat, 23 July 2016, 21:11:49 »
You would probably looking at a board 35g topre (very uncommon) or gateron clears (linear) IIRC.
Offline letsjigsrocks
  • Don't you think its cute?
« Reply #15 on: Mon, 25 July 2016, 16:47:01 »
Or you could try boards that are less travel distance.
VA87MR
Offline kingpilcrow
« Reply #16 on: Mon, 25 July 2016, 17:59:50 »
https://m.youtube.com/watch?v=9yg3s77nAMQ
Lol
Offline chyros
  • a.k.a. Thomas
« Reply #17 on: Mon, 25 July 2016, 19:35:37 »
Lol
Yeah that was it, recognise that instantly xD .
