Author Topic: Hello Folks, need some newbie suggestions  (Read 3191 times)
Offline cowboysfan
« on: Sun, 24 July 2016, 18:22:58 »
Got myself an IBM Model M a few months ago. It's a unicomp version so not a classic. Got it for about 40 bucks. I love the buckling springs. Poor quality photo but great keyboard.
143329-0
I'm looking to make some modifications to the KB. First I wanna add some EL wire under the keycaps to illuminate it. I really wanted to make it backlit( but don't think that'll happen). But from a quick google perusal, the EL wire illuminating looks great on some kbs but others looks crappy. Any tips on pulling it off?
I also want to change up the colors on the keycaps. Where can i get keycaps for the model M. Another option is for me to dye it. But i'm looking for new caps and haven't found much luck.
Offline mike52787
  • Alps Aficionado
Re: Hello Folks, need some newbie suggestions
« Reply #1 on: Sun, 24 July 2016, 22:34:02 »
If you like your model M, you'd love a model F, a true classic :)) As for the caps, if youre interested in blanks, unicomp will sell you full blank sets. I dont know a thing about the el strips, but it interests me. Im not a huge fan of backlighting, but I think a backlit m would look cool :D
« Reply #2 on: Tue, 26 July 2016, 05:41:47 »
Welcome to Geekhack!
Nice keyboard, and USB built-in?  One up on the classic Model M ;)
There's a thread about backilghting a Model M, with a link to one that Phosphorglow partly backlit, might give you some inspiration.
There's also this page that talks about making a backlit keyboard with EL wire: http://lifehacker.com/5609060/make-your-own-backlit-keyboard
Offline cowboysfan
« Reply #3 on: Sun, 31 July 2016, 19:13:28 »
Nah, Usb Isn't built in. It's an adapter. I considered modding it to be bluetooth, but then i realized how heavy this thing is and i'd get nearly no benefit with BT. I'll be sure to try out EL wire soon. Will post pictures.  :D
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Mon, 01 August 2016, 14:30:17 »
$40 Unicomp huh? You can't really go wrong with some EL wire. If you happen to mess up the case while modding you can always buy a shell from Unicomp. Welcome :)
« Reply #5 on: Tue, 02 August 2016, 05:59:03 »
There's enough room in the case for a BT adaptor and some batteries, but you'd have to open the case each time to change the batteries, and it's definitely not facilitating portability :))
Offline cowboysfan
« Reply #6 on: Thu, 04 August 2016, 17:49:12 »
yup exactly. If it were an HHKB for example i'd definitely mod it to have a bluetooth chip. I'd probably add a li-poly battery and a microusb charging port. No batteries to change.
in other news i bought myself some EL tape. It's gonna be a fun little project. I gotta figure out how to cut this stuff though. It's too wide to fit in between rows.
« Reply #7 on: Sun, 07 August 2016, 02:04:36 »
There's a Bluetooth mod or two for the HHKB, and also an HHKB with native Bluetooth now, although I understand that you do have to change batteries on it.
