Author Topic: Rgb Underglow?  (Read 8367 times)
Offline Hellcatz
Rgb Underglow?
« on: Wed, 27 July 2016, 19:23:16 »
Hey I have facew PCB and I was wondering how I would manage to setup rgb Underglow layout on it? Something like this http://m.imgur.com/a/lECL4
« Last Edit: Thu, 04 August 2016, 13:53:24 by Hellcatz »
Offline Hellcatz
Re: Rgb Underglow?
« Reply #1 on: Thu, 28 July 2016, 18:55:53 »
bump
Offline kohi
Re: Rgb Underglow?
« Reply #2 on: Thu, 28 July 2016, 19:12:28 »
the pcb should support smd rgb LEDs from what I'm seeing on the wkl website
perhaps just buy some LEDs, solder them on, and program them using the software that wkl provides?
Offline Hellcatz
Re: Rgb Underglow?
« Reply #3 on: Fri, 29 July 2016, 02:32:47 »
there are no places for smd led on the underside of the pcb
Re: Rgb Underglow?
« Reply #4 on: Fri, 29 July 2016, 03:09:06 »
An SMD under the PCB would not show much, if any, light above the PCB.
Offline Hellcatz
Re: Rgb Underglow?
« Reply #5 on: Fri, 29 July 2016, 06:36:43 »
not really trying to light the upper side of the pcb just the underside
Offline tacnificent
Re: Rgb Underglow?
« Reply #6 on: Fri, 29 July 2016, 10:21:29 »
I have 3 WKL kb and they all have solder pads for RGB. They should be W1, W2, 3, etc
http://imgur.com/LGe5ckZ
Offline Hellcatz
Re: Rgb Underglow?
« Reply #7 on: Fri, 29 July 2016, 16:46:10 »
Offline Hellcatz
Re: Rgb Underglow?
« Reply #8 on: Fri, 29 July 2016, 16:59:37 »
i didnt know that rgb led come in 2 pin layouts
Offline nugglets
Re: Rgb Underglow?
« Reply #9 on: Fri, 29 July 2016, 17:17:25 »
They just constantly change colors, though. No ability to program them.
I'm not sure if/how you could add RGB to a Face.W, which is what you have btw. That's not a WKL B.Face.
Offline Hellcatz
Re: Rgb Underglow?
« Reply #10 on: Fri, 29 July 2016, 17:46:55 »
no way to just get a roll of rgb leds and somehow tap into the usb for power?
Offline nugglets
Re: Rgb Underglow?
« Reply #11 on: Fri, 29 July 2016, 17:58:36 »
You have the breakout pins for power up near the USB port, so technically yes. But you would also need a data signal, which usually means soldering to an unused pin on the controller. Then you need a firmware that supports the underglow, using the pin on the controller to provide the data. I don't know if such a firmware exists for the FaceW. It could almost certainly be done, but I'm not sure if it has or not.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: Rgb Underglow?
« Reply #12 on: Sat, 30 July 2016, 20:54:50 »
You are hitting the key point!
There is an extra USB power holes near USB connector on my PCB.
RGB smd stips are much more powerful,  flexible way than the current static dull underglow, in my opinion.
And very soon we will have thin fiber RGB strings on the market.
When i proposed underglowing and RGB strip to winkeyless.kr, he had no idea what is it, and expressed no liking LEDs and even underglowing, back in 2013.
Now I am working with more variety of people to design Next generation PCBs and FIrmware, Softwares.
« Last Edit: Sat, 30 July 2016, 21:10:51 by sprit »
Offline Hellcatz
Re: Rgb Underglow?
« Reply #13 on: Sat, 30 July 2016, 21:25:02 »
so which which connection would I solder the 3 pins from the rgb strip to. I got 4 holes ground clk(d+) data(d-) vcc
Offline sprit
Re: Rgb Underglow?
« Reply #14 on: Sat, 30 July 2016, 21:59:21 »
Hello ! Dear Hellcatz
Depends on if the strip has clock or vcc
Offline Hellcatz
Re: Rgb Underglow?
« Reply #15 on: Sat, 30 July 2016, 23:13:40 »
WS2812 RGB LED? also found a post https://github.com/jackhumbert/qmk_firmware but cant seem to make sense of it
Offline Hellcatz
Re: Rgb Underglow?
« Reply #16 on: Wed, 03 August 2016, 19:46:27 »
Bump
Offline TerryMathews
Re: Rgb Underglow?
« Reply #17 on: Thu, 04 August 2016, 10:09:46 »
It looks like you have the v1 PCB. Here's the instructions for underglow:
http://blog.winkeyless.kr/169
Offline Hellcatz
Re: Rgb Underglow?
« Reply #18 on: Thu, 04 August 2016, 13:56:15 »
i have a face w pcb from sprit not from winkeyless
Re: Rgb Underglow?
« Reply #19 on: Thu, 04 August 2016, 14:20:43 »
Am I crazy or did your post say bface earlier?
Offline Hellcatz
Re: Rgb Underglow?
« Reply #20 on: Thu, 04 August 2016, 16:19:06 »
maybe
Offline Hellcatz
Re: Rgb Underglow?
« Reply #21 on: Fri, 05 August 2016, 09:00:20 »
144472-0
So found the pins sprit was talking about and would just need to know how to connect the rgb strip to it. Haven't got the rgb strip yet but open to suggestions.
Offline Capmerica
Re: Rgb Underglow?
« Reply #22 on: Fri, 05 August 2016, 13:24:04 »
May I ask what Pcb you are using? Because if you are using the one from wlk it is totally compatible for the underglow.
Offline Hellcatz
Re: Rgb Underglow?
« Reply #23 on: Fri, 05 August 2016, 20:13:16 »
sprit face w pcb. I know its possible as sprit gave me the blessing but dont think there is any software support on it0
Offline Hellcatz
Re: Rgb Underglow?
« Reply #24 on: Mon, 08 August 2016, 20:27:55 »
bump
Offline MajorKoos
  • 1 life please. Extra large.
Re: Rgb Underglow?
« Reply #25 on: Sat, 03 September 2016, 06:06:41 »
I've using same PCB as you on 5 or 6 of my keyboards.  It's a great PCB, especially with the boot mapper client, but hard to hack.
The data pin for the RGB strip needs to be connected to a spare pin on the controller.  I haven't spotted any pins which have been broken out from the controller, so it's likely going to involve soldering a wire directly to one of the controller pins.  The D+ and D- pins by the USB port are for USB data.  Perhaps it's possible to hijack one of the pins along the bottom which are used for programming the PCB, but I'm not sure.  My soldering skills aren't good enough to make a connection direct to the controller without borking the board so I've held off the temptation.
Then there is the firmware.  Either I need to figure out how to get the ps2avrGB firmware to run on the board or figure out how to get QMK onto it and reprogram it.  I believe there is some additional complexity because of VUSB which needs to be solved in that case.
In the end I took the easy way out and went the GH60/QMK route for my RGB needs.
