Author Topic: Silicone dust covers  (Read 1850 times)
Offline tiger
« on: Thu, 28 July 2016, 13:33:28 »
Any recommendations for silicone dust covers for HHKB and realforce 87u?
Offline Macsmasher
Re: Silicone dust covers
« Reply #1 on: Fri, 29 July 2016, 00:07:27 »
http://www.elitekeyboards.com/products.php?sub=access,roofs
These aren't silicone, but I have three of these. Two for my 87Us and the small one for my HHKB. They fit perfectly and do the job. I highly recommend them.
Offline jcoffin1981
« Reply #2 on: Fri, 29 July 2016, 19:07:11 »
I purchased this on Amazon.  It's not meant for any keyboard specifically, but they come in a few sizes.  The one I purchased is 18" wide.  I'm not sure if it's plastic, vinyl, silicone, etc., but it does  what I need it to which is protect the board when not in use.  Very inexpensive and worth a look.
If you are looking for something that fits like a glove you will have a harder time.  THis is perfectly fine.
https://www.amazon.com/Computer-Dust-Solutions-Antistatic-Translucent/dp/B00DTGG22M/ref=sr_1_1?ie=UTF8&qid=1469837061&sr=8-1&keywords=keyboard+dust+solutions
