Author Topic: Problem with JellyKey spacebar  (Read 5377 times)
Offline Lipton
« on: Fri, 29 July 2016, 14:01:46 »
Anyone else running into this?
I installed it on my NovaTouch and my old WASD. And both have the same issue, if I try to hit the space bar with my left thumb, the spacebar dips to the left like it's a sinking ship. If I click in the center or the right side, it's fine however.
Here is the problem :(
Offline E3E
Re: Problem with JellyKey spacebar
« Reply #1 on: Fri, 29 July 2016, 14:46:26 »
Just at a glance, it seems like tolerance issue. Like that the stems on the space bar that fit onto the stabilizers are too loose. A brush of superglue on the inside should tighten them up. Just... Make sure you let the super glue dry first. :P
Offline caligo
« Reply #2 on: Sat, 30 July 2016, 07:23:47 »
I had a similar problem with my WhiteFox and a Round 5 spacebar. The solution was to put a small piece of tinfoil between the stabilizer stem and the keycap and then push it down. Works like a charm, and less risky than super glue.
Offline Tactile
« Reply #3 on: Sat, 30 July 2016, 12:57:38 »
To the OP: this thread might help:
https://geekhack.org/index.php?topic=28632.0
REΛLFORCE
Offline cookie
    • Deskthority
« Reply #4 on: Sun, 31 July 2016, 03:35:14 »
Scotch tape is your friend!
Try this here:
http://m.imgur.com/poLbH?r
« Last Edit: Sun, 31 July 2016, 03:36:59 by cookie »
Offline Lipton
« Reply #5 on: Sun, 31 July 2016, 21:37:03 »
Ah thanks guys! Lol yeah scotch tape / foil it is :D
Offline E3E
« Reply #6 on: Sun, 31 July 2016, 21:44:36 »
The non-permanent methods never crossed my mind. :P Yeah better option if you don't want to risk either messing it up or possibly being too tight with other keyboards.
Offline kingnestea
« Reply #7 on: Sun, 14 August 2016, 16:07:59 »
