Author Topic: Seeking a PS/2 tenkeyless keyboard  (Read 2849 times)
Offline Matej
    • MatejBlahut.com
« on: Sun, 31 July 2016, 02:11:36 »
Hello gentlemen,
Sorry if this question has been asked before, but I have not had much luck searching for an answer.
I have been looking for a mechanical tenkeyless PS/2 keybard, without luck so far. Preferably a clicky one with MX blue switches, but that is of secondary importance. When I say PS/2, I mean a keyboard with a dedicated PS/2 connector. I do not want to use a USB to PS/2 adapter, purely due to personal obsessive reasons. :)
Another option would be a keyboard with a removable cable on which I could replace the mini-USB to Type A cable with a mini-USB to PS/2 cable. In fact, this option would be even more preferable, since it would allow me to use nearly any keyboard with a removable cable. However, once again I am not sure if such a cable can be purchased anywhere.
I have lurked here for a while looking at people's pretty keyboards, and I thought that if anyone could give me some suggestions for a keyboard to use, it would be people on this forum.
Thank you ahead for any advice.
Offline klennkellon
  • I like bottoming out
Re: Seeking a PS/2 tenkeyless keyboard
« Reply #1 on: Sun, 31 July 2016, 02:35:14 »
Try going for an IBM Model M. Most have a detachable cable, use PS/2, and use one of the best clicky "switches" you can find.
Offline Matej
    • MatejBlahut.com
« Reply #2 on: Sun, 31 July 2016, 04:01:03 »
The Model M certainly is a cool vintage keyboard, though I was hoping to find something that can still be purchased new, and in the generic smaller footprint of the 'Filco' style.
Though I am guessing that may be asking for the impossible.
Rosewill does include a Mini-USB to PS/2 cable with their RK-9000 keyboards, but they do not seem to sell it separately.
« Last Edit: Sun, 31 July 2016, 04:11:45 by Matej »
« Reply #3 on: Sun, 31 July 2016, 05:21:58 »
Perhaps you could get someone like Pexon to make one for you.
Offline Matej
    • MatejBlahut.com
« Reply #4 on: Sun, 31 July 2016, 23:07:37 »
Quote from: rowdy
Thank you for the tip, that would be perfect!
« Reply #5 on: Thu, 04 August 2016, 05:48:11 »
Quote from: rowdy
Or as you're in the US there's MiMiC Cables.
Offline y11971alex
  • Looking for Toronto meetup
