Author Topic: 60% MKB  (Read 1993 times)
Offline TypingNoob
60% MKB
« on: Mon, 01 August 2016, 01:08:01 »
I was wondering what I could get as my 60% MKB. I own a custom Varmilo Va87mr and a B.Fake for home use. I need something nice and sturdy for travelling.
I was thinking maybe the White Fox with zealios would be a good choice. Any other suggestions for the 60% range would be greatly appreciated.
Re: 60% MKB
« Reply #1 on: Mon, 01 August 2016, 02:57:05 »
It depends a lot what you're looking for - ANSI or ISO?  Metal or plastic case?  Backlighting?  Nice stock caps?  Switch preference?
Offline TypingNoob
Re: 60% MKB
« Reply #2 on: Mon, 01 August 2016, 04:46:16 »
ANSI layout. Aluminum case. I dont care much for backlighting, but if there is its an added bonus. Thick PBTs. If it came down to switches blues or zealios, but i know zealios dont come stock, so if theres a kit with zealios, then id go for that.
