Author Topic: Sneak Peek (pictures revealed)  (Read 215007 times)
Offline toneman77
Re: Sneak Peek (pictures revealed)
« Reply #50 on: Sat, 13 August 2016, 02:48:09 »
Holy...
PCB with LEDs and silencers that work with a plate. Apart from a split spacebar you checked all the boxes on my wishlist. After 3 boards I thought: that's it, but now i think I see my dream ISO HHKB-ish-y keyboard on the horizon... (here)
Also: would be awesome if the next PCB of yours could handle split spacebars (one can dream)
Awesome.
Offline Vadurr
  • Valar Morghulis
« Reply #51 on: Sat, 13 August 2016, 03:39:00 »
HYPE :p
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« Reply #52 on: Sat, 13 August 2016, 03:49:17 »
Are there any plans to produce plate mount stabilizers in the future?
No, there are no plans to make Plate mounted stabilizers as of right now. Most "end game" / high end custom keyboards use PCB mount Cherry stabilizers only. The only issue at hand with PCB mount Cherry stabs were that they sometimes popped out, and screw in types would strip the plastic. My PCB stabilizer solves both issues present on PCB Cherry stabilizers.
Take my money! This will be my first 60% keyboard.
Any chance for a 1800 layout?  ;D
Nothing in the roadmap. If it does happen, would be next year. :P
Offline asgeirtj
« Reply #53 on: Sat, 13 August 2016, 06:37:41 »
Will these silencing clips shorten the keytravel? (hope they will, that's a big advantage of o-rings imo)
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Zeal
  • * Moderator
« Reply #54 on: Sat, 13 August 2016, 06:46:40 »
Barely, the rubber part is under 1mm thick.
Offline ramnes
  • T fou, mec?
« Reply #55 on: Sat, 13 August 2016, 07:11:59 »
What firmware?
TMK port for now. Will work on a fancier UI down the road.
QMK or something else? I'd be really hyped if QMK
Offline Brammm87
« Reply #56 on: Sat, 13 August 2016, 08:09:19 »
Well, I now know which PCB I will be putting in that hyperfuse case. Holy ****  :eek:
pls gief bbv2
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #57 on: Sat, 13 August 2016, 11:01:12 »
Love that you're using a TMK fork for your firmware. Looking forward to this one!
Offline Purp
  • the colour, not the weed
« Reply #58 on: Sat, 13 August 2016, 13:38:41 »
Are these screw in stabs compatible with the WKL B.Face X2 / B.87 PCBs?
Offline xondat
  • i'm not a star
« Reply #59 on: Sat, 13 August 2016, 14:01:39 »
Screw in stabs work with the standard holes for non-screw in so one can only presume so.
Offline japanitrat
« Reply #60 on: Sat, 13 August 2016, 16:07:24 »
Does the PCB support a 1.25 L Shift + 1U as well?
Edit: typo.
« Last Edit: Sat, 13 August 2016, 16:20:21 by japanitrat »
Offline Zeal
  • * Moderator
« Reply #61 on: Sat, 13 August 2016, 16:31:21 »
Edit: typo.
Yes, that's part of ISO support.
Offline japanitrat
« Reply #62 on: Sat, 13 August 2016, 16:44:12 »
Ah, right. Thanks a lot!
Offline edel781
« Reply #63 on: Sat, 13 August 2016, 22:27:11 »
Will we have a white version of the PCB?  :confused:
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #64 on: Sun, 14 August 2016, 00:21:08 »
What is the actual color of the PCB? My colorblind self just assumed it followed Zeal's purple color scheme.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline itskuroi
« Reply #65 on: Sun, 14 August 2016, 01:03:11 »
Royal purple lookin
Offline Zeal
  • * Moderator
« Reply #66 on: Sun, 14 August 2016, 01:59:17 »
White/Black PCBs are a bit overdone...So it'll be purple for the time being. Will consider other colours in future revisions.
Your assumption is correct, and it'll be produced in a dark-ish purple colour.
Side note: Just had my friend @munch come by to test drive the "Zealencios" (silencing clips) with his 65g lubed Linear Zealios in a champagne red LZ-CP. Will render the footage and post some typing comparison videos very shortly. :)
Offline munch
« Reply #67 on: Sun, 14 August 2016, 02:05:39 »
my pleasure! love these things (no shill, just sounds amazingly dampened now :p)
Offline icyskyz
« Reply #68 on: Sun, 14 August 2016, 02:05:42 »
I am sorry if this question has been asked somewhere but when would those screw-in stabilizers be available?
Thanks in advance!
My collections - flickr | HWS Keyng Collector |
Offline Geekmie
« Reply #69 on: Sun, 14 August 2016, 06:29:07 »
How about under glow support for this PCB?
Offline joey
« Reply #70 on: Sun, 14 August 2016, 06:31:27 »
Not happening.
Offline Zeal
  • * Moderator
« Reply #71 on: Sun, 14 August 2016, 09:07:51 »
Thanks in advance!
Will be GB'd along with R4 Zealios, Zeal60 RGB PCB, silencing clips, etc, sometime this month.
The Zeal60 RGB PCB is already approaching maximum current allowed per USB 2.0 spec. 70+ RGB LEDs = 210+ "individual" LEDs being lit up on a 60%. Until USB 3.1/C matures/stabilizes a bit more, this is the most that can be done for now. There are USB breakout pins for the user to mod and attach RGB LED strips if they so desire...But that's not recommended unless you know what you're doing. :P
« Last Edit: Sun, 14 August 2016, 09:10:07 by Zeal »
Offline Weiss
  • Impulse buying at its finest
« Reply #72 on: Sun, 14 August 2016, 14:44:05 »
Woah, the new Zealencios sound pretty good.  :thumb:
Personally I have to say that I'm more of a fan of the unsilenced more than the silenced. I dunno, with linears I think a lot of the appeal for me is the bottoming out sound. I'd probably use them on something like Blues or Aristotles to highlight the clicky sound more than the bottom out sound.
Either way I'm sure I'll pick some up.  :p
Offline Zeal
  • * Moderator
« Reply #73 on: Sun, 14 August 2016, 17:42:48 »
Thanks for sharing the vid above. :)
Here's a how-to vid on installing them on your kb:
Offline Aricil
« Reply #74 on: Sun, 14 August 2016, 18:34:39 »
I'm a little confused about how this actually works. So does this take away from the bottom out sound... or..? Cuz I'm thinking that this may be a good replacement for O-rings on my blue switch board.
Professional amateur.
Offline Zibob
« Reply #75 on: Sun, 14 August 2016, 18:37:24 »
I need those stabilisers. Got a CPSQ in the works and it is getting a little bit of an ultimate everything board. I missed I think a massdrop for clear/gold stabs and kind or regret it as now that parts are starting to arrive for the CPSQ and gold springs and gold sip sockets look a little out of place next to black and blank steel stab wire. I assume the screw in is compatible with regular PCB cutouts for cherry stabs, will it fir in the chunky CPSQ plate/frame?
Is there a way to know when these are up so I don't miss them?
EDIT:
These take down the return top click that the switches make when you let off them, so together with orings this should really help bring down the sound a bit.
« Last Edit: Sun, 14 August 2016, 18:40:19 by Zibob »
Offline Zeal
  • * Moderator
« Reply #76 on: Sun, 14 August 2016, 20:04:12 »
EDIT:
My screw in style stabilizers fit in regular PCB mount stab holes.
The silencing clips reduce both bottom out and up stroke noise, without giving users the mushy feeling with o-rings.
Offline SKD
« Reply #77 on: Mon, 15 August 2016, 01:57:32 »
I'm need that PCB. Where can I sign up to be notified the GB is available? I'm always late to GB and they're all gone!
Offline Geroximo
« Reply #78 on: Mon, 15 August 2016, 07:18:08 »
I wanted to solder my Nerd60 build today.
Now I have to wait for those transparent stabilisers.  :-\
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #79 on: Wed, 17 August 2016, 04:40:42 »
And now I have another reason to delay my Weaven board. 😋
|||My other keyboards :
x
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Sneak Peek
« Reply #80 on: Wed, 17 August 2016, 07:45:11 »
Theyre on slack!
Just waiting to build my all zeal x60 so we can be soul mates.
Why slack where they'll get buried in half an hour rather than here where they'll stay visible? :(
LoL  :))    So true
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Zeal
  • * Moderator
« Reply #81 on: Wed, 17 August 2016, 09:33:55 »
Newsletter found at the bottom of my site: https://zealpc.net/
Or just F5 GH/Reddit everyday.
Offline tofgerl
« Reply #82 on: Wed, 17 August 2016, 11:48:28 »
Having tried QMX silencers only to find that they don't work with the combination Zealios+SA... Do these?
Also, the name is now official Zealencios.
« Reply #83 on: Wed, 17 August 2016, 11:53:56 »
OMG that PCB. Great job Zeal and Wilba!!
Offline gnarlsagan
  • Billions and billions... of keycaps.
« Reply #84 on: Thu, 18 August 2016, 22:35:24 »
I would also like to know this.
Offline vincentalpha
« Reply #85 on: Fri, 19 August 2016, 04:16:32 »
Is it possible to achieve this layout with your PCB, Zeal?
145801-0
Offline Lost2Frostbite
« Reply #86 on: Fri, 19 August 2016, 07:58:13 »
This is one my dream layouts also!! Hope is becomes possible:)
Offline xondat
  • i'm not a star
« Reply #87 on: Fri, 19 August 2016, 08:02:47 »
No it isn't. There isn't a mount for the fn/up key.
« Reply #88 on: Fri, 19 August 2016, 08:05:51 »
Maybe look into the 62/60, that may be more up your alley. Though, I still wouldn't skip out on Zeal's new stuff.
Offline kawasaki161
« Reply #89 on: Fri, 19 August 2016, 08:29:23 »
With iss being mia it sadly seems like the 62/60 is rather dead atm.
« Reply #90 on: Fri, 19 August 2016, 11:28:35 »
62 keyboad looks good and it has the arrow that I wanted.
However, I am not a fan of the winkeyless style keyboard. I am heavy window user and Windows is one of the most key I use. Plus, I dont have to buy extra for another winkeyless keycap.
Offline Zeal
  • * Moderator
« Reply #91 on: Fri, 19 August 2016, 12:42:18 »
I don't have any SA caps to test, but would imagine that it would only be partially silenced due to SA keycaps lacking the cross on the stem. Only the upstroke would be silenced.
No, however if you're not a heavy right_shift user, you could do something like this:
145877-0
145879-1
« Last Edit: Fri, 19 August 2016, 12:43:59 by Zeal »
Offline tofgerl
« Reply #92 on: Fri, 19 August 2016, 13:52:05 »
It had nothing to do with the cross, the Zealios housing were thicker than the Gaterons, so when the QMX-thingies were on the SA caps became stuck when depressed. Works fine on gateron blues.
Offline Zeal
  • * Moderator
« Reply #93 on: Fri, 19 August 2016, 15:44:34 »
Sounds like you didn't have the QMX clip on properly. Zealio/Gateron housings share the same footprint, and are a slightly wider base than Cherry.
Regardless, the Zealencio clips fit on Zealios, Gateron and Cherry switches without issue.
Offline tofgerl
« Reply #94 on: Fri, 19 August 2016, 16:04:08 »
No, they mount the same way. Believe me, I know how to listen to a click sound.
Offline edel781
« Reply #95 on: Sun, 21 August 2016, 18:42:54 »
I can somewhat confirm this. Cherry POM/GMK caps feel "sticky" when QMX clips are used, possibly due to greater wobbling in Zealios. This does not happen with Gateron caps because they have narrower stems.
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #96 on: Sun, 21 August 2016, 19:24:09 »
Oh man.  I guess I better stop buying **** I don't need off the classifieds.  I was just thinking of building a new 60... Now I have a fantastic reason.  +1 for those stabs!  Thanks for all your hard work and dedication! R4 Black Bird and now a Zeal 60.  Now I just need to figure out how to cook the books for my wife... Lol.
Offline Zeal
  • * Moderator
« Reply #97 on: Mon, 22 August 2016, 21:54:43 »
https://zealpc.net/collections/group-buy-pre-orders
R4 & new products auto-opening at 8PM PDT (6mins)
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #98 on: Mon, 22 August 2016, 22:05:49 »
Picked up a pcb, stabs, and some switches.. Guess I have to build an mx board now  :-X
Offline Vypr
« Reply #99 on: Mon, 22 August 2016, 22:11:40 »
Ordered some stabs and silencing clips, so excited  :eek:
Thanks Zeal  :thumb:
current keyboard: VE.A (home) WhiteFox TrueFox (home)  MD1 Infinity (Home)  Infinity Ergodox (work)
future keyboards:
