Author Topic: Keycaps set for The White Fox  (Read 7959 times)
Offline AresTheGod
« on: Fri, 05 August 2016, 06:37:05 »
Hi,
I'm about to buy the keyboard "The White Fox". It's a 60%~ with the arrow keys. Here's the layout :
But I'd like to change the keyset. If possible I'd like a Blue and Grey layout or something to match with a black desk and a black pc and a blue watercooling in it.
Maybe something like this : http://pimpmykeyboard.com/dsa-dolch-keycap-set/ or like this http://pimpmykeyboard.com/sa-symbiosis-keycap-set/
« Last Edit: Sun, 07 August 2016, 16:44:41 by AresTheGod »
Offline ndakota79
Re: Keycaps set for The White Fox
« Reply #1 on: Fri, 05 August 2016, 09:41:35 »
The Amazing Chocolatier keycap set has got a kit specifically for the white fox. It's currently on Massdrop: https://www.massdrop.com/buy/the-amazing-chocolatier-custom-sa-keycap-set
Offline AresTheGod
« Reply #2 on: Fri, 05 August 2016, 11:37:25 »
Yeah, seen it. But I don't think the color scheme will fit. Suppose I'll just keep the original keycaps
Offline unoab
« Reply #3 on: Fri, 05 August 2016, 14:31:59 »
If everything on your desk is black, why not go with a black and blue setup for the board?  So get a set like https://www.originativeco.com/products/classic-black, and then use the blue accent keys from the whitefox kit if you are getting it.
Though if you are buying the barebones kit (so without keycaps), then you will have to get blue accent keys elsewhere, but I think that would look pretty good on a whitefox.  I have WoB cherry keys on mine with some grey arrow keys and it looks nice on the board, so I would imagine the classic black keys would as well.
Offline AresTheGod
« Reply #4 on: Fri, 05 August 2016, 15:15:51 »
Thought of that but won't it look a bit "too sad" since there's a lot of dark color? Wanted grey so it would be a bit more clear.
Offline Adgar
    • Pheilcia
« Reply #5 on: Tue, 09 August 2016, 01:45:07 »
WF is one of my favorite one
Offline zisb
  • Aluminium, learn to spell it.
    • zisb.io
« Reply #6 on: Sat, 13 August 2016, 23:02:40 »
Wouldn't most TKL keysets be okay for the WF.. you would just have a couple of leftover keys.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #7 on: Sat, 13 August 2016, 23:30:23 »
The shift key is small -that's kinda the big difference
-Dana
