Author Topic: Corsair K65 Lux vs Blackwidow X Chroma Tournament Edition  (Read 2440 times)
Offline gugaprado10
« on: Fri, 05 August 2016, 12:48:05 »
I'm in search of a tenkeyless mechanical keyboard and found these two interesting. I type quite a lot and I generaly play strategy or action games.
Offline y11971alex
  • Looking for Toronto meetup
Re: Corsair K65 Lux vs Blackwidow X Chroma Tournament Edition
« Reply #1 on: Fri, 05 August 2016, 16:02:19 »
Instinctively, I'd recommend the Corsair, simply because it's a more established brand with a less gimmicky history; however, neither Corsair nor Razer are particularly well-received here.  In fact, most of us have found switches preferable to Cherry MX in brands like Honeywell, Alps, and IBM.
Offline klennkellon
  • I like bottoming out
« Reply #2 on: Fri, 05 August 2016, 17:05:39 »
I agree. If you have to choose between the two the Corsair is the better option, but there are better options than MX switches.
Offline y11971alex
« Reply #3 on: Fri, 05 August 2016, 17:10:51 »
Grr.  We're all waiting for Unicomp to come up with their RGB Model M!
Offline Screwdriver
« Reply #4 on: Fri, 05 August 2016, 20:46:50 »
Nothing wrong with Cherry MX switches for gaming.....
Out of the two I would get the Corsair.....Not a fan of the Razer.
« Last Edit: Fri, 05 August 2016, 20:49:16 by Screwdriver »
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
