Author Topic: topre o-rings to silence the upstroke  (Read 4584 times)
Offline Giorgio
« on: Sat, 06 August 2016, 12:52:28 »
I know that there is the landing pad mod (to reduce the thickness it must be ironed though).
I wonder instead what o-rings you use. Someone says that the o-rings mod isn't very good, because they can roll and move thus preventing the key from going upwards.
It's quite common consensus that they must be quite thin, in order to reduce key-chatter.
The sliders on the NovaTouch are 7mm in diameter.
The inside clearance of the underside of the NovaTouch at the smallest clearance is 13mm.
I was using o-rings as silencers that were 1/16" thick. That was much too thick, so I would reccomend using something here that's 0.4mm-0.9mm thick. I had major ghosting issues.
Conclusion for best results with silencers:
7mm inside diameter
12.5mm outside diameter (maximum)
0.4mm - 0.9mm thickness
https://www.reddit.com/r/MechanicalKeyboards/comments/3r063x/keyboard_science_some_novatouch_measurements/
https://www.reddit.com/r/MechanicalKeyboards/wiki/modifications_topre#wiki_switch_silencing
I wonder if these washers o-rings can be considered adequate, or if it's better to get the dental bands
http://www.ebay.com/sch/i.html?_nkw=orthodontic+bands+3%2F16
12.3mm O/D X 8.2mm I/D X 0.8mmThk
http://www.ebay.co.uk/itm/M8-Nylon-Washers-Choose-from-10-different-sizes-20-per-pack-/131872774548?var=&hash=item1eb43ad994:m:m4QFY4tuzOsn3ZJTBCTAcTg
12.1mm O/D  x 7.4mm I/D x 0.7mm Thk
http://www.ebay.co.uk/itm/M7-Nylon-Washers-7mm-8mm-I-D-Choose-2-sizes-LARGE-QUANTITIES-/142066144206?var=&hash=item66b75cf805
Red 12.8 X 7.3 X 0.8
http://www.ebay.co.uk/itm/M7-Red-Fibre-Washers-Choose-3-sizes-various-quantities-available-/142058068568?var=&hash=item66b6ef858e
I know that there are these o-rings, but they are quite expensive.
http://www.ebay.co.uk/itm/252485995488
Offline Tactile
Re: topre o-rings to silence the upstroke
« Reply #1 on: Sat, 06 August 2016, 15:03:11 »
landing pads and o-rings are for MX. For Topre:
https://geekhack.org/index.php?topic=73940.0
EDIT: I just now saw the last link in your post. Those are not o-rings, and they are the right stuff. Regular O-rings are too thick.
« Last Edit: Sat, 06 August 2016, 15:10:51 by Tactile »
REΛLFORCE
Offline Giorgio
« Reply #2 on: Sat, 06 August 2016, 15:13:14 »
these nylon washers shouldn't be bad...
plus the size seems right
Offline Tactile
« Reply #3 on: Sat, 06 August 2016, 15:22:28 »
They might fit but I don't know how effective at silencing they'll be. The trick is to have something which is very thin (so you don't goof up the stroke and the feel) and which will also do the silencing. Finding a material like that isn't easy and apparently it's expensive stuff.
REΛLFORCE
Offline Giorgio
« Reply #4 on: Sat, 06 August 2016, 15:51:32 »
it seems that the diameter of the stem for topre was wrong, and that the correct one is 8.4mm for novatouch, and 8.2mm for some other variants of topre
Offline jerue
  • (Whenever that happens :P)
« Reply #5 on: Sat, 06 August 2016, 16:08:33 »
anything but the silenced sliders from Topre directly is ****
Offline Giorgio
« Reply #6 on: Sat, 06 August 2016, 17:00:36 »
and where can I get those????
Offline sony
  • Formerly ultraidiot
« Reply #7 on: Sat, 06 August 2016, 21:28:44 »
Buy a silenced board like the hhkb type s. Realforce usually have s at the end of the model for silenced sliders. The sliders are purple but are not mx compatible like the Novatouch.
Offline Giorgio
« Reply #8 on: Sun, 07 August 2016, 16:47:46 »
Is there anyone who can kindly confirm what is the diameter of the stem, and what is the maximum external diameter of an oring?
It should be 8.4mm internal and 12.5mm external....
« Reply #9 on: Sun, 14 August 2016, 03:03:41 »
